I know there is not much for clearance back there. It's gonna be tight. I wonder how this setup compares to beans h2e setup.
I'm probably gonna wrap those up-pipes to keep the heat down on the firewall...
Might have to bring the uppies in from the bottom?
What about getting them ceramic coated? I am hoping mine can be coated but who know.
You might be able to get them in from the bottom if you pull the trans but at that point I would just pull the engine so you know for sure. I am trying to figure out the best way to make my kit so that I can get each pipe off individually.
Also on the H-max kit I think it either uses the stock pipes or at least it keeps the pipe individual and separate from the collector.
The Hypermax kit uses seperate uppies and a collector but they are not stock Ford pieces.
Originally Posted by FARM69
I don't want to pull the engine. That's a lot of work.
This may be a bigger challenge than I thought.
Unbolt the cab mounts and you can raise the cab off the chassis, there's only 6 of them, one at each corner of the cab and 2 more outboard of the radiator support.
