Front end vibration
Old Jun 8, 2008 | 06:18 PM
F-4 GUY's Avatar
F-4 GUY
Front end vibration
Hi, I have a 1977 f-100, 2wd, 6 cyl, standard, 3 speed on the column with power steering. I bought this truck new and have taken good care of it for 31 years. I am having problems with the front end. It just started shimming a bit when I get up over 60mph and when I hit a slight bump, it shakes a bit more. I have jacked up the front end to see if anything is loose and it all appears tight. I have new shocks and tires and it has been greased and lubed regularly. Is there any way to tell if it is a tie rod end, kingpin, steering link? It is all original and wears the tires evenly.
Old Jun 8, 2008 | 07:43 PM
Randomtasker's Avatar
Randomtasker
Does your truck have a track arm? My 79 4 x 4 has a track arm and the bushings wear out frequently. Causes violent vibration in my front end, enough to cause the tailgate to fall off the truck, the glove box door falls open, and everything goes flying around the cab. The track arm on the 4 X 4 spans from the drivers side someplace over to the passenger side of the front axle.
More likely in your case with a 2wd, you have a loose wheel bearing. Any noises?
Old Jun 8, 2008 | 09:49 PM
Shamus's Avatar
Shamus
Sounds like alignment shop time if you cant spot it.
Old Jun 9, 2008 | 01:45 AM
fasthauler's Avatar
fasthauler
The easiest way I have found to check out a front end is to put it on jackstands with the wheels just off of the ground. Get under the thing, grab a wheel, and start shaking it. If something is loose, you will see it. Any loose bushings, knuckles, ball joints, etc. will really show up with no weight on them. This way you don’t have to enlist someone to help you.
It sure sounds like a tire balance problem though. You said you have new tires on it. Did you have problems with the old tires? Usually vibrations at certain speeds is tire balance problems.
Old Jun 9, 2008 | 10:43 AM
rbaker6336's Avatar
rbaker6336
could need king pin bushings
Old Jun 9, 2008 | 11:01 AM
78workhorse's Avatar
78workhorse
My 2cents. could be any of the above. Wheel balance(new tires), wheel bearing, kingpin, ball joints, stabilizer. Maybe even ragjoint? Maybe. If its the new tires, do you feel it in the steering wheel or the seat? Wheel=front tire. Seat=rear tires. A tire guy told me that once. Don't if any truth to it thou.
Old Jun 9, 2008 | 12:09 PM
Blue Bomber's Avatar
Blue Bomber
ummmmmm.... if its all factory, i would think its time to start rebuilding the front end anyways. just my opinion. i have a 1974 F-100 2wd and the front end shake is all from my kingpins and bushings.
Old Jun 9, 2008 | 12:14 PM
rbaker6336's Avatar
rbaker6336
from my experience the 6 bangers seemed to shimmy worse from slightly worn king pin bushings than the V-8s for some reason
Mcrafty1
Oct 24, 2014 08:04 PM
Orpackrat
20
Sep 4, 2014 02:48 PM
breedo99
17
Nov 21, 2012 03:00 PM
Nightstalker
Aug 3, 2010 10:10 PM
Josh Adams
22
Feb 22, 2003 02:08 AM
