Sponsored by: Real Truck
Steering issue
Old Sep 25, 2014 | 02:15 PM
Mcrafty1's Avatar
Mcrafty1
Steering issue
I have an 07 F350 and recently it has started to do strange things concerning steering.....It will start to pull to the left and when I counter that it will hold for a bit and then lose all resistance and dart to the right, I counter steer and the process starts all over. Sometimes it will only do this for a short time and sometimes it's a prolonged event (like 30 miles or more) The tires wear like iron and everything is in order under the front end. Has anyone else ever experienced this and if so found the cause/fix?
Old Sep 25, 2014 | 03:26 PM
Pit Crew's Avatar
Pit Crew
Ball joints, jack up front end and take the wheel off. Grab the hub and shake up and down. Whatch it move......
Old Sep 25, 2014 | 03:37 PM
Mcrafty1's Avatar
Mcrafty1
Yikes! will do, Thanks for the reply.
Old Sep 26, 2014 | 08:37 AM
tsedgar's Avatar
tsedgar
Hawkerpilot05
Check front u-joints. That was my problem. Even though front hubs are unlocked you still need the front ujoints working. I had one side frozen on both planes and the other frozen on 1 plane. Only 100K miles but driven in MN with all the salt.
2005 F250.
Old Sep 26, 2014 | 02:00 PM
Mcrafty1's Avatar
Mcrafty1
2005 F250.
Thanks for the input, I'll check both the ball joints and the ujoints when I get a chance to do so, My truck has 118,000 now and I'm in Mains so the winters have done their damage just like Minn. All good info and will give me a place to start looking. Thanks again.
Old Sep 26, 2014 | 10:44 PM
tsedgar's Avatar
tsedgar
Hawkerpilot05
Another thing to add is that my front u-joints had grease zerks installed. I guess when Ford changed the front end in 2005 they added them. I had always been told that there was no grease zerks to grease. I wish I would have known as I have always been told that the ones with grease zerks will wear out faster then the sealed ones. Maybe mine would have lasted longer. My new ones do and will be greased regularly.
Old Sep 27, 2014 | 07:25 AM
Greg B's Avatar
Greg B
It could also be the track bar ball joint is worn or the steering gear itself is bad. I had an '88 F250 that did that. After replacing ball joints and checking axle shaft u-joints the problem was still there. The steering gear was the problem. Replaced the gear and problem solved.
Old Sep 27, 2014 | 08:25 AM
Mcrafty1's Avatar
Mcrafty1
Thanks for that info.......and by 'steering gear' do you mean steering box?
Old Sep 29, 2014 | 08:54 PM
Greg B's Avatar
Greg B
Yes. Steering gear box.
Old Oct 23, 2014 | 05:34 PM
Mcrafty1's Avatar
Mcrafty1
UPDATE!!!!! Ok, I had my truck fixed and the problem was the U-joints on the front axle shafts...specifically one u-joint was frozen and both where extremely dry and on there way out....long story short the truck now handles and drives like a new one, if your truck is acting like I described mine to be it is a good place to start looking. I hope this helps others. I was about to pull the trigger on a new Red Head gear box and although that would have been nice it wouldn't have fixed my problem.
Old Oct 23, 2014 | 06:02 PM
PSD666's Avatar
PSD666
Glad you got your problem fixed! My '08 F-350 w/ 150K is having the same issue. It starts around 15 MP/H or so and won't go away until I come to a complete stop. I'm suspecting it is the u-joints. Are there 2 in the front axle? This is my first diesel truck, so forgive my lack of knowledge on these rigs.
Old Oct 23, 2014 | 06:18 PM
Greg B's Avatar
Greg B
I'm glad it's fixed. I'm going to thoroughly inspect all front suspension and steering parts on my '08 next spring. It's not a daily driver, so there is no sense of urgency. I have 68K miles, so I suspect axle shaft u-joints or steering box. Tie rods and drag link are good. I'll also check ball joints and track bar while I'm under it.
Old Oct 24, 2014 | 03:56 AM
Mcrafty1's Avatar
Mcrafty1
Yes there are two ,one on each side between the axle tube and the hub. Mine only had one out of four on one cross actually 'froze' the others where very dry so I had both sides replaced. although the old ones had grease fittings (which I didn't know nor did the previous owners by the looks... I don't believe they were ever greased) I now know that the new ones do and will service them on a regular basis.
Old Oct 24, 2014 | 03:59 AM
Mcrafty1's Avatar
Mcrafty1
Your o8 should have grease fittings, maybe you could get by with just a good greasing of yours and be fine, I certainly would give it a try before I tore into it, the vacuum hubs (if you have them) have seals that need to be replaced when you take them apart to get to the u-joints and those parts get pricy very fast.
Old Oct 24, 2014 | 08:04 PM
Greg B's Avatar
Greg B
I'll certainly give that a try. But I do have some slop on the sector shaft by the pitman arm. I checked my friend's '03 and his sector shaft has no slop. I suspect I may have some wear on the sector shaft or the box wear the sector shaft goes thru. I only have 68K miles on the truck. So I'll be checking things over thoroughly in the next 1000 miles or so.
David7.3
Sep 18, 2014 12:31 PM
Fordman96
May 22, 2012 11:27 PM
rafter3
6.4L Power Stroke Diesel
Oct 5, 2011 02:28 PM
nkm
General Diesel Discussion
Jun 2, 2011 12:13 PM
just another truck
Apr 22, 2010 11:59 AM
