Bronco II Ford Bronco II
weird widow prob...
Old Jun 4, 2008 | 08:34 PM
baddmove's Avatar
baddmove
weird widow prob...
hey all..i have a 89' 2.9L , a/t, edie bauer, BII i just got from a friend and it has an issue with the passenger side electric window.i can roll it up/down from the driver side..but can't from the passenger side unless the door is open.. if i pull on the wire and close the door as far as i can, it will go up/down. i can see the wire runs inside the fender well,do i need to take off the fender and make sure it is hooked up/connected right?
And it's nice to be back, missed having a BII for so long!!
Old Jun 4, 2008 | 08:36 PM
baddmove's Avatar
baddmove
It should say WINDOW...LOL
Old Jun 4, 2008 | 09:22 PM
80351's Avatar
80351
Yes but that is much more fun.
Give up the widow. If you don't get an answer here try The Ranger Station.
The Pros on everything Ranger based.
Old Jun 5, 2008 | 06:57 PM
rebocardo's Avatar
rebocardo
No, the connector is in front of the battery, where acid can leak on it of course ;-)
Disconnect there and remove all the way to the door to repair the broken wire, just about impossible to do with the harness in the vehicle. You will have to remove the air cleaner, battery, etc. to do the job.
Tylus
Jan 5, 2012 10:18 AM
truckmonger1
Jun 13, 2010 09:20 PM
dmkolb
Bronco II
37
Dec 16, 2009 01:22 AM
baddmove
Electrical Systems/Wiring
Jun 5, 2008 12:31 PM
kable
Aug 23, 2004 09:44 PM
