Sponsored by: Real Truck
Auto Up/Down Window Switch Mods
Old Dec 26, 2011 | 12:58 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Do they exist? My Google Foo is lacking tonight.
My 09 Mustang had auto up/down for both windows. My 08 Expy has auto up/down for drivers window. I'd love to add the auto up function to my current button that does Auto down.
Also adding auto up/down would be cool for all 4 window switches
Also, can you mod the 4 way switch? Kids like to play with rear window door controls so I always have the "lock" button on. This keeps wife from controlling her window...which leads to annoyance on my part.
Just wondering if anybody has ventured down this path? And yes, I know it's all lazyness. Don't care. You get used to the small things and want them in your current ride
Old Dec 26, 2011 | 06:46 AM
ahco4693's Avatar
ahco4693
Just want to follow this!!! NO idea how to do it but would liek to do it too if someone figures it out!!!
Old Dec 26, 2011 | 08:42 AM
rwilimo's Avatar
rwilimo
You will need to install aftermarket window rollup modules, I used to do lots of these years ago and they work very well.
Old Dec 26, 2011 | 11:54 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
got links to this? name of the module?
I ain't skeer'ed of a little wiring. just need to be pointed in the right direction
Old Dec 26, 2011 | 12:41 PM
rwilimo's Avatar
rwilimo
Take a look here: http://www.directed.com/guides/manua...N530T_1-00.pdf
There are also other models such as the 529T, not quite sure what the differences are, you should read up
Old Dec 26, 2011 | 06:43 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
thx for link, not exactly what I was after. That's an alarm add on
I was hoping you could modify the OEM switch to trigger this action?
Old Dec 26, 2011 | 07:37 PM
XL1200LTD-Keith's Avatar
XL1200LTD-Keith
One Touch Down window module kits, you need one per door for each direction.
PonyPerformance.com~ One Touch Down window module kit
This might help you figure out how to accomplish this on the F250 Super Crew. Read posts 1 thru 4, and then an easier version on post 11.
HOW TO: Passenger Window Lock Bypass - F150online Forums
Good luck!
Old Dec 26, 2011 | 07:57 PM
1975StroppeBaja's Avatar
1975StroppeBaja
One thing to remember when trying to rig a one-touch UP is the safety factor. Its not a problem for one-touch down, but one-touch up needs to have some sort of way to detect if something is between the glass and the window frame. So you don't get arms or heads crushed!
The 2010 Dodge trucks we have at work have one-touch up and, while its moving up, if you press down on the glass with your hand, it will switch directions and go down.
This aftermarket unit lists a "load sensor" which I believe is what I'm talking about.
Amazon.com: AutoLoc WC1000 One Touch Up And Down Window Unit: Automotive
Old Dec 26, 2011 | 08:04 PM
XL1200LTD-Keith
I agree! I have mine set up for down only.
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
thx for links. I'm going to check them out. My Mustang and Expy are load safety'd also. They both stop with light pressure to prevent crushing.
Old Dec 27, 2011 | 04:46 AM
rwilimo's Avatar
rwilimo
Yes this is an alarm add on, however it does not require an alarm. It will give you one touch up and down of 2 windows from the standard switch's with the safety features that stop the glass if it encounters an obstacle.
Old Dec 27, 2011 | 10:52 AM
xmontex4's Avatar
xmontex4
Subscribing! do these require you to modify the switch itself? on my truck its almost like a button and you have to press down on the window switch then down again to make it go to auto.
Old Dec 27, 2011 | 11:35 AM
rwilimo's Avatar
rwilimo
No modification to the switch at all, just to the wiring.
Old Dec 27, 2011 | 12:18 PM
xmontex4's Avatar
xmontex4
interesting, so how does it work is it always auto up and down with no inbetween?
Old Dec 27, 2011 | 12:26 PM
rwilimo's Avatar
rwilimo
The ones I used to have were auto with a click, press and hold, then let go for standard option
