Door lock/window switch Problems
Old Aug 23, 2004 | 03:54 PM
kable's Avatar
kable
I have a 1989 F250 4x4 XLT.
The passenger side power window doesn't work (from either side). The passenger side door lock switch doesn't lock/unlock the passenger side door but does lock/unlock the driver's side door.
The driver's side power window works fine but the driver's side switch for the passenger side window does not move the passenger side window up/down. The driver's side door lock operates the driver's side door (lock/unlock) but doesn't operate the passenger side.
Any ideas?
Ugh! Any help would be greatly appreciated.
THanks.
Dan
Old Aug 23, 2004 | 08:01 PM
Dealford's Avatar
Dealford
Welcome to FTE!
Have you removed the passenger side switches, door panel, or passenger side wiring harness to test for power anywhere? If you are getting power at all points then you may be into a motor & lock actuator. Pretty odd that both would fail near the same time though.
If not, remove the door panel & get the test light out to see what you do have.
AL.
Old Aug 23, 2004 | 09:44 PM
kable's Avatar
kable
Thanks for your advice!
Dan
stowbilly96
Mar 22, 2020 07:35 PM
jimandnena
Aug 10, 2014 09:46 AM
99cummins
Dec 18, 2013 09:45 AM
kev100
Feb 18, 2011 07:30 PM
pablocruz69
Mar 28, 2009 11:44 AM
