Sponsored by: Auxito
Tranny problems
Old Jun 1, 2008 | 09:26 AM
4trax's Avatar
4trax
Tranny problems
Hello, I have a 99 F-150 ext. cab 4x4 with the trans. shifting fine but when it does shift it bangs into gear. 1st to 2nd ok but 2nd to 3rd its bangs. Now the O/D shift is flashing. Took it to the dealer they said it needs a tranny. It only has 115,000 on it and has had the tranny flush at 80,000. Don't pull anything heavy and drive with O/D off in town or anything under 45 MPH. Is there something else that could possible be wrong with it? Like shift solenoid or shift sensors or something?
Old Jun 1, 2008 | 03:17 PM
projectSHO89's Avatar
projectSHO89
Take it to an independent transmission specialist and get another opinion.
Old Jun 1, 2008 | 04:58 PM
triton54's Avatar
triton54
Mine did the same thing, had it rebuilt and it still does it, going in tomorrow so i'll update you for sure
Old Jun 1, 2008 | 05:16 PM
4trax's Avatar
4trax
10-4 Thanks guys. Let me know for sure.
Old Jun 1, 2008 | 08:19 PM
96f150's Avatar
96f150
Sounds like you may have a broken 2-3 accumulator spring maybe. I had this problem with the 4R70W in my 96.
Rich
Old Jun 1, 2008 | 08:27 PM
4trax's Avatar
4trax
I have the 4R100 tranny.
Old Jun 1, 2008 | 08:33 PM
96f150's Avatar
96f150
Ah, Ok. I would still have a few different shops take a look into it, maybe the flush knocked some sludge loose and its hanging up in the valve body then.
Rich
Old Jun 2, 2008 | 02:54 AM
streethealer's Avatar
streethealer
IDK but if it were mine I'd fix it...LOL That's a dang nice looking truck. I have the same one, just without the aftermarket goodies... A second opinion is a must, but it sounds like a valve body issue or electrical issue to me as long as it is not slipping... Good luck.
Old Jun 2, 2008 | 06:16 AM
4trax's Avatar
4trax
No slipping whats so ever. Just that bang when in shifts. It's like when you have or had a real stout tranny shift kit in a C-6 or something it really bangs to the next gear as if you were to stay in the throttle it might take out a universal.Thanx for the compliments.
Old Jun 2, 2008 | 11:57 AM
advocate's Avatar
advocate
unless you swapped trannies you should have the 4R70W in your truck. The 4R100 was used in the Navigator and Lightning.
When you did your flush what kind of fluid did you put in it? Are you getting any codes that can be checked using a scanner/tuner or autozone or something?
Old Jun 2, 2008 | 11:59 AM
4trax's Avatar
4trax
Nope it has original tranny. I give ford my vin# and it came back 4R100 that is in it.
Old Jun 2, 2008 | 07:58 PM
triton54's Avatar
triton54
The cheaper the fix the better, i let mine go for a while and eventually it started slipping real bad. Good luck!
Old Jun 4, 2008 | 11:33 PM
4trax's Avatar
4trax
Tranny is junk. Took to Ford dealer for tranny install 2900.00 out the door I was quoted. Will see.
Old Jun 4, 2008 | 11:49 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
regular f-150's could get the 4r100 to, just not as common as the 4r70w... i bet a tranny specialest could do it for a more reasonable price... i put a used 4r70w in myne for 300bucks... it had 120k on it and my truck had 140k on it... im at 175k now no troubles... And i tow quite a bit, and run it real hard most of the time Might be a cheaper option, most people dont have any trouble with there trannys...
mvedepo
6.7L Power Stroke Diesel
321
Mar 11, 2019 08:27 PM
kobaltblue
1966 - 1977 Early Broncos
31
Jan 15, 2015 06:59 PM
78SB300
32
Nov 1, 2012 04:04 AM
Dwest
19
Feb 3, 2010 08:36 AM
BushRat
Jan 12, 2008 06:00 PM
