Got a new gauge!! It rocks!!
on
I haven't used the scroll function yet. I hope to today. I think this gauge could replace most other gauges that are needed. though For the money it takes to get a pyrometer added to this gauge I would get a stand alone gauge. I think if I had no gauges at all, I would get a double pod for either the pillar or the dash. Then fill it with a Scan gauge and a stand alone pyrometer. Then I would also add oil pressure and coolant temp to the scan gauge.
Right now I have pyro, boost, trans temp, oil pressure, coolant temp and the scan gauge. The only thing I will want to add in the future once I go to an electric pump fuel system is fuel pressure. I will add that to the scan gauge I think.
on
Also just had a 45 minute drive and got the cycle readings setup. It will scroll thru 4 screens each with 2 units displayed (8 total readings). The cycle rate can be changed from very fast to very slow. It really is a great option! I love this gauge even more the more I use it!
The only down side of an "All in One" gauge is that with individual gauges indicating: EGT, Trans Temp, Coolant temp, Boost, Fuel Press, Oil Temp.
These can all be scanned in a Nano second as you are driving.
Granted the All In One gauge has other options that are useful, helpful and desirable but one would generally use these when stopped while performing various tests.
I can see using this gauge only in conjunction with the majority of the gauges that I currently have mounted. I'm not trying to spoil the moment for anyone and I'll probably end up with one of these little beauty's myself but I will also probably keep most if not all that I have mounted/installed now. JMHO
Rog
Rog
on
Rog
Rog
As far as sun wash on the face of the gauge. I have not noticed it to be a major issue. the display is very bright. But I do have a crew cab with dark tint so it might be more of an issue in a regular cab.
