Hpop?
Old May 28, 2008 | 01:35 PM
jimwilsonmasonry's Avatar
jimwilsonmasonry
does a sd hpop give a hp boost or is it just a supporting mod for injectors
Old May 28, 2008 | 01:57 PM
tjbeggs's Avatar
tjbeggs
Mainly its a supporting mod. If you constantly set a CEL for low HPO Pressures then you might notice and increase in power. I noticed the difference when I installed mine. THe midrange and top end pulled harder, longer.
Old Jan 1, 2009 | 10:17 PM
sawz5's Avatar
sawz5
you just follow rubberduck's directions an d it's a breeze. one thing though the torque on the bolt for the gear is 95lbs. instead of 160lbs. i really had to crank a long time to get mine to fire up, but it finally started. i got my pump from area diesel in carlinville,il cost me $408.
cmcolfax
Sep 3, 2009 08:32 PM
crazer42
Dec 18, 2007 05:54 PM
alchymist
Modular V10 (6.8l)
19
Nov 16, 2007 08:34 AM
kymadan
Apr 20, 2007 08:47 AM
Grabber
Dec 12, 2006 03:21 PM
