Sound Clip Talk
Old Mar 16, 2011 | 07:26 AM
  #286
liljon20's Avatar
liljon20
That's actually my dads truck. Stock manifold into a Y pipe with two 12" glasspack and pipes to the rear. Everything after the Y is stainless.
Want that sound on my 87 but don't think it will happen.
Old Apr 10, 2011 | 04:01 PM
  #287
captwdhall's Avatar
captwdhall
I've read this forum 3 times now and I'm still not sure what to do. I am trying to significantly increase my MPG's. I have a '96 I6 EFI auto and 140,000 miles. My truck is throwing a couple codes relating to the O2 sensors, so I'm thinking about replacing cats with 1 high flow, new O2 sensors, new 3" exhaust with a glass pack. I'm not sure how loud this is going to be. This is my work truck and I dont want to pull up to a customers house with an obnoxious truck. I'm mostly concerned about fuel economy since I drive about 3-5k per month, but I do like the low rumble. Any suggestions?
Old Apr 10, 2011 | 04:08 PM
  #288
liljon20's Avatar
liljon20
Some guys will tell you that the cat is needed, I personally don't use one. You may need one depending on how many o2 sensors you have, and their location.
I recently put on some Raptor turbo mufflers on my truck and I love the sound, its pretty quiet, but has a good sound. Glasspacks may drone in your cab.
Old Apr 10, 2011 | 04:13 PM
  #289
captwdhall's Avatar
captwdhall
I have two cats now, O2 sensor before and after the first one. Thats why I want to remove both cats and install one High Flow cat.
Old Apr 10, 2011 | 04:20 PM
  #290
liljon20's Avatar
liljon20
In my opinion and others will disagree, both cats do nothing for the engine except make it harder to breathe. If you want to keep a high flow cat, I would put on a turbo muffler or a glass pack, but for economy gains I would look into an intake, lrr tires, an aero-shell, or something to make less work for the engine.
Old Apr 10, 2011 | 05:09 PM
  #291
captwdhall's Avatar
captwdhall
I dont think I can delete both cats. Won't that throw codes? I finished installing the intake. What are lrr tires?
Old Apr 10, 2011 | 05:25 PM
  #292
coffeetwitch666's Avatar
coffeetwitch666
i maybe wrong.... but as long as your down stream o2 sensor is a wide band sensor you should be ok
Old Apr 10, 2011 | 05:41 PM
  #293
liljon20's Avatar
liljon20
I have both cats off no codes.
Low rolling resistance tires. Not ideal for a truck but they would help
Old Apr 10, 2011 | 06:13 PM
  #294
captwdhall's Avatar
captwdhall
how do I know what o2 sensor I have. I think I need to replace one or both anyways... Its throwing codes for them.
Old Apr 10, 2011 | 06:20 PM
  #295
captwdhall's Avatar
captwdhall
even if its not throwing codes, wont that hurt overall fuel economy? I'm trying to get the highest mpg's possible. I tow a small trailer (around 2500lbs) once a week, so towing isnt a huge part of my truck. But like i said, I do drive a lot of miles each month.
Old Apr 10, 2011 | 06:21 PM
  #296
coffeetwitch666
depending on the codes it could be your cats are clogged. generally in mass air flow systems like the 96 efi's are, the down stream should already be a wide band. which is why liljon has no codes without his cats. fyi if you wanted to add an afr gauge just to monitor your engine ive heard thats the o2 you would want to tie into.
Old Apr 10, 2011 | 06:25 PM
  #297
liljon20's Avatar
liljon20
I get about 17 now, I was getting about 14 before I did the exhaust. Hoping to get to 20 soon
Old Apr 10, 2011 | 06:40 PM
  #298
captwdhall's Avatar
captwdhall
again, will removing the cats hurt my mpg's? what is the difference in a wideband and the first o2 sensor?
Old Apr 10, 2011 | 08:51 PM
  #299
coffeetwitch666
removing the cats will NOT hurt your mpgs and will improve exhaust flow... the first o2 is a narrow band... all it does is tell the computer rich or lean right now for immediate changes to fuel trim.... wide band is kinda like a slower sweep that helps determine over all trim and monitor emission... get rid of the cats if you can, i.e. no emissions inspection... if you need one on your truck there are several high flow after market cats that are still budget friendly.
Old Apr 10, 2011 | 09:45 PM
  #300
captwdhall's Avatar
captwdhall
Should I have bungs welded into the new pipe for the o2 sensors?
