Modular V10 (6.8l)
flowmaster 40
Old May 22, 2008 | 07:48 PM
pkenn7's Avatar
pkenn7
flowmaster 40
i have an 02 with a banks cat back, and im not totally thrilled with the sound. i was wondering if anyone has opinions on the flowmaster 40, and could i just buy the muffler and install it to my banks pipes?
Old May 22, 2008 | 08:23 PM
dew the thunder's Avatar
dew the thunder
I put one on my stock 99. The pipes still looked good and had good clean bends so I just had the muffler replaced. I went with the stock exit point and its really not as loud as I want it but it does get some attention.
Old May 22, 2008 | 08:34 PM
pkenn7's Avatar
pkenn7
whats the difference between the 40 and the super 40?
Old May 22, 2008 | 09:40 PM
meanv10's Avatar
meanv10
What exactly didnt you like about the sound?
Old May 23, 2008 | 01:54 PM
TeamMudd's Avatar
TeamMudd
heres's a selection of sound clips of the 10er!!
Sound & Video Clips
between the 40 series and 50 series, it's a toss up. both have a great rumble to them!! its more of what you want, or don't want to hear. the 40series will be louder in cab, the 50 will have a good tone, and less interior noise. the super 44's have a smaller case, and slightly less interior noise (from what i've been told). the 70 series is a good upgrade from factory, with slightly more rumble than stock, and little to no interior noise!
Old May 23, 2008 | 02:52 PM
dew the thunder
I dunno what the difference between the two 40s are but the shop that put my Super 40 on said there wasn't a difference...
Clips - The site will ask you to download the clips... they are in WAV format
Startup (give a few seconds... I was slow)
Rev to 3k
These sound clips were recorded with the device on the passenger side of the rear bumper.
Old May 26, 2008 | 02:02 AM
RACERX7775's Avatar
RACERX7775
i just installed a super 44 on my v10 X with the stans headers y pipe. definately loud in the truck. actually rattles the plastic panels.and a 4 1/2" stainless tip.
Old May 26, 2008 | 08:06 AM
pkenn7's Avatar
pkenn7
any flutter with the y pipe? do you have stock manifolds? hows the performance increase?
Old May 26, 2008 | 09:05 AM
cc322's Avatar
cc322
You didnt even have to buy the whols banks kit, our trucks come with 3" tubeing from the factory, all you needed to do was change the muffler and maybe throw a tip on the end, saves alot of cash. BTW I am running the FM 50 series and like it fine.
Old May 26, 2008 | 12:04 PM
RACERX7775's Avatar
RACERX7775
i have all stock manifolds. the only thing i did was cut out the old y pipe, muffler, and tip. replaced them with the super 44, bigger y pipe, and bigger tip. i dont really notice any power difference. no real flutter. alot louder though. i like it alot.
Old May 29, 2008 | 12:06 AM
igotoneforya's Avatar
igotoneforya
I have a super 40 with duals at the muffler and 5" cans. Sounds great with no drone and not too much interior noise.
Flowmaster says the super 44 is the most aggressive yet. I put a super 44 on my Wrangler and it is tame. The engine out does the muffler at 3000 rpms. Good start up rumble but that is about it. I know, diff engine but still. I know I can cut of some of the tail pipe on the jeep to increase the noise but...biggest diff between the 40 and 44 is thickness. 44 is 4" while 40 is 5".
Old May 29, 2008 | 07:40 AM
dkf's Avatar
dkf
I suggest an FM50 SUV muffler. Its got more growl to it than then banks, is a hair milder than the the 40 series but it has more volume and anti-drone chambers which is better suited for a tow vehicle. Banks uses a 3.5" tailpipe, you can use a 3" muffler just have a muffler shop with a hydrauilic pipe expander open up the outlet of the muffler to fit inside the banks tailpipe.
Old May 29, 2008 | 11:21 PM
Raider50's Avatar
Raider50
I just had a super 40 put on my 460 in the place of the stock muffler with out tips(yet im going to get the ones with resonators ) and the only time i can even here my exhaust is when my rpms are really low because it is quit enough that my motor noise will drone out the exhaust. I would not recommend them if you are going for something loud.
rangerrn
May 10, 2017 08:23 AM
greentruck72
May 22, 2016 10:39 AM
bulldoggish
Escape & Escape Hybrid
Jan 18, 2014 12:36 PM
BlackGold1955F100
Mar 25, 2013 10:53 PM
Rbuller24
Exhaust Systems
May 11, 2003 06:46 PM
