Sponsored by: Real Truck
More height for leveling kit
Old May 20, 2008 | 09:01 PM
bc56845's Avatar
bc56845
I put a single add-a-leaf in my '99 superduty to level the front. At the time I couldnt decide how to do it, whether or not to order the donahoe racing mini packs, or one of the other kits, but I decided on the add a leaf because it was cheaper. now I regret it. It still needs to come up an inch or 2. Is there anything I can do to bring it up a little without taking the add a leaf out? I'm afraid the donahoe mini packs will make it too high with the leaf still in there, or may not even work with it. Any ideas?
Old May 21, 2008 | 12:10 AM
zack7.3's Avatar
zack7.3
Try some of the shackles on Ebay. They lift the front 1-1 1/2 inches.
Old May 21, 2008 | 12:49 AM
aldridgec's Avatar
aldridgec
I second lift shackels of any kind if you are ok with the ride and just need more height.
Old May 21, 2008 | 02:34 AM
milburn's Avatar
milburn
What about the pinion angle?Will it be too much or not enough with shackles and an add of leaf?
Old May 21, 2008 | 03:19 AM
aldridgec's Avatar
aldridgec
If anything it will give you a little more caster, which should help straight ahead steering feel and return to center. It can and probably will change the pinion angle, but not enough to worry about. Most guys I know that run them haven't had any problems with the change in angle.
Old May 21, 2008 | 06:31 AM
rbloodhound's Avatar
rbloodhound
I just installed the shackels from ebay on my 04. The ride seems the same. Pinion angel is good. It took about 3 hours to install. I probably could have cut that time in half with the help of a buddy. I had to install mine myself. I paid around $60 for the shackels.
Old May 21, 2008 | 06:46 AM
birdman127's Avatar
birdman127
I would take the add a leaf off and install the mini pack. Ride is un-changed and your shocks don't need to be replaced as the pack goes under the shock mount. You can take out a leaf or two on the mini packs if you so wish too!
Old May 21, 2008 | 07:11 AM
ffadragon's Avatar
ffadragon
I also did the same thing as you.
I went with the cheap add-a-leaf and that was a teribble mistake.
You really need to take the add-a-leaf OUT. I took the add-a-leaf out then did the longer shackles that you can get off e-bay. The truck rides great now. of course I also have Bilstien 5100 shocks too.
I got the shackles that were supposed to raise the truck 1 1/2" but it raised it about 2 1/2" I have a 5.4L and I see you have a 7.3 so your front end in much heavier.
Do you have the rear lifted at all???
Old May 21, 2008 | 08:32 AM
03_PSD's Avatar
03_PSD
might be a dumb question but do the shackles give you a bouncier ride or stiffer ride?
Old May 21, 2008 | 09:03 AM
ffadragon's Avatar
ffadragon
No, You already have shackels on you truck, you are just taking the old ones out and putting in a little longer ones. I noticed no bouncing.
We are talking about the rear of the front spring. The shackle is what holds the spring to the frame. Remember we are only talking about trucks that have front leaf springs 04 and older. 05 and newer have coils in the front.
Old May 21, 2008 | 12:47 PM
rbloodhound
My truck doesn't ride any diffrent.
Old May 21, 2008 | 09:48 PM
bc56845's Avatar
bc56845
Thanks for all the replies. I'll have to look into the shackles on ebay. Whats the sellers name?
Old May 21, 2008 | 10:46 PM
aldridgec's Avatar
aldridgec
KoolAidMan888
Jan 15, 2012 09:58 AM
HTTTRH
Feb 18, 2007 09:42 PM
Rugger99
Aug 26, 2006 06:39 PM
Eric Larson
Jan 30, 2006 04:48 AM
shakerpilot
Mar 13, 2004 01:48 PM
