Sponsored by: Real Truck
Looking to add 40s?
Old May 15, 2008 | 04:48 PM
BrianBo's Avatar
BrianBo
Looking to add 40s?
I already have a 8in fabtech lift and im looking to lift my truck higher to add 40s any ideas?
thanks
Old May 15, 2008 | 07:52 PM
StealmyTruck's Avatar
StealmyTruck
Here's one....don't?
Old May 15, 2008 | 07:55 PM
adambomb's Avatar
adambomb
the best 40" tires i had on my old truck were Pro Comp X Terrains. they were 40x13.5xR17. they looked sick, weren't super noisy, and did i say looked sick! i actually got better milage when i switched to these tires from the other Mickey Thompson's i had but those ones were 15.5" wide so that could be.
i also really liked the 39" BFG Baja Projects but those were out of my budget.
Old May 15, 2008 | 08:29 PM
DCSpecial's Avatar
DCSpecial
What year is your truck?
Old May 15, 2008 | 09:18 PM
UGA33's Avatar
UGA33
If you got an 08 and some serious cash laying around you can go my buddies route:
Old May 15, 2008 | 09:46 PM
Bigskyduty's Avatar
Bigskyduty
need some more pics of that truck UGA- and go dawg's-
Old May 16, 2008 | 12:14 PM
DCSpecial's Avatar
DCSpecial
If you have 99-08 with serious cash the One Up Offroad setup with coilovers in the front or the front & rear is the way to go
Old May 19, 2008 | 08:50 AM
snurtle112's Avatar
snurtle112
you want to clear 40's??do a little trimming or go body lift would be cheap route...or go drive around pismo,bako area and check out all the lifted trucks
Old May 19, 2008 | 09:21 AM
TP83's Avatar
TP83
I never recommend a body lift, cut out flares would be the best route if you dont want to lift it any higher.
Old May 19, 2008 | 11:41 AM
cartmanea's Avatar
cartmanea
With cutouts you only need about a 6" lift to clear 40s, maybe not even that much.
Old May 19, 2008 | 06:46 PM
Jack_99V10's Avatar
Jack_99V10
I'm running 6" Skyjacker and 3" body lift... the 39.5 IROKS I have rub on the leafs as well as the front bumper as well as the rear inner fender.
Proper offset would fix some of these issues, I've already removed material from the bumper... but you're going to want some offset as well as some trimming. They are going to stick out some if you don't want them to rub inside when you turn,.
Old May 19, 2008 | 07:39 PM
DCSpecial's Avatar
DCSpecial
On road I didn't rub with 40/15.50R20 Toyos. But I modified the corners of my front bumper when I frenched the lights in, so that helps a lot.
Only rubbing was on the leaf springs. Back on 38/15.50R20s now for more clearance.
Old May 19, 2008 | 09:20 PM
cartmanea's Avatar
cartmanea
I don't want to rub on or off road
Old May 19, 2008 | 09:25 PM
DCSpecial's Avatar
DCSpecial
For no rubbing with cut-outs you need 8" lift with 12" wide wheels and either trim the stock bumper or your ORT bumper will work.
Old May 20, 2008 | 07:36 AM
snurtle112's Avatar
snurtle112
or why not just go with a high enough lift to clear them without trimming..10in lift should suffice
