trouble code P2285
Old May 18, 2008 | 07:19 PM
chiefn10's Avatar
chiefn10
trouble code P2285
my wife's check engine light came on on her 03 F-250. went to autozone to use ther OBD II and got a trouble code of P2285-Injector Control Prssure Sensor Circuit Low. looked the code up in my haynes Manual and didn't see P2285. after checking the codes, the check engine light cleared, but i am still skeptical about what it is and don't want her getting stuck somewhere and the truck not starting. any suggestions? thanks
Old May 18, 2008 | 09:15 PM
bismic's Avatar
bismic
ICP sensor is a comon failure point in 2003's. It is a pain to get to as I understand. Hold on for some research material ........
Old May 18, 2008 | 09:18 PM
bismic's Avatar
bismic
Injection Control Pressure (ICP) Sensor https://www.motorcraftservice.com/pu...1527/adobe.gif
Printable View (240 KB)
Removal: All vehicles
1. With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Section 100-01.
Vehicles with automatic transmission
1. Remove the transmission fluid level indicator.
2. Remove the retaining nut and disconnect the transmission fluid fill tube from the stub tube and position it aside.
https://www.motorcraftservice.com/pu...9/A0065712.gif
All vehicles
1. Raise the vehicle.
2. Remove the bolts and the turbocharger heat shield.
https://www.motorcraftservice.com/pu...3/A0065771.gif
4. NOTE: It will be necessary to position the heat wrap aside. Disconnect the injection control pressure (ICP) sensor electrical connector.
5. https://www.motorcraftservice.com/pu...2/A0077287.gif
6. NOTE: Use a 1-1/16 inch 12 pt. deep flare nut crowfoot wrench, such as a Snap-On® AN850817B, GAN850817B or equivalent, to remove the sensor. Remove the ICP sensor.
7. https://www.motorcraftservice.com/pu...9/A0079758.gif
Installation:All vehicles
1. NOTE: Verify the ICP sensor has the O-ring in place. Install the ICP sensor.
https://www.motorcraftservice.com/pu...0/A0077288.gif
2. Connect the ICP electrical connector. Position the heat wrap back over the electrical connector.
3. NOTE: Engine removed for clarity. Install the turbocharger heat shield and bolts.
https://www.motorcraftservice.com/pu...4/A0065669.gif
1. Partially lower the vehicle. Working from outside the right wheel area, engage the transmission fluid fill tube to the stub tube.
2. Lower the hoist.
3. Install the fluid fill tube retainer nut.
https://www.motorcraftservice.com/pu...2/A0065741.gif
4. Install the transmission fluid level indicator.
Old Feb 23, 2011 | 09:45 PM
anthony mayer's Avatar
anthony mayer
If you plan on replacing the ICP, look at the wire itself. I thought my ICP sensor was the problem and replaced it twice thinking I kept getting a bad ICP sensor. Turns out the wire was burnt and was shorting out. Definately look at this first before you dump $100 on a new sensor.
Old Feb 23, 2011 | 11:15 PM
chiefn10's Avatar
chiefn10
wow, this post is almost 3 years old, and you replied now? lol
anyway, i replaced the ICP for about $60, 3 hrs labor, and 4 hrs of cussing, but thanks for the input.
Old May 27, 2012 | 02:58 AM
kayooh's Avatar
kayooh
Did you use a hoist!?
Thanks.
Restlesswildman
May 19, 2014 04:46 PM
gamaliel
Jan 7, 2013 08:33 AM
galcath
Mar 1, 2011 11:14 AM
SLMDLM
Jan 20, 2009 10:12 PM
discoknut
Sep 9, 2008 09:37 AM
