Sponsored by: Real Truck
injector control pressure sensor
Old Sep 8, 2008 | 11:49 AM
discoknut's Avatar
discoknut
I was driving my 03 F-250 w/ 6.0 diesel. Engine light came on and with my Banks power PDA I ran the trouble codes and one came up- P2285 ICP- Injector control pressure sensor circuit low open cicuit, short to ground ICP sensor. What I am wondering is, where is it located, is it hard to replace, and is it a common problem on a truck with 90,000 miles? I am handy in the garage and what seams to be better than the local Dealer when it comes to diesels.
Old Sep 8, 2008 | 12:03 PM
madjak's Avatar
madjak
discoknut,
Welcome to FTE!
Go down to the 6.0 forum and you will find some help.
Good luck
Old Sep 8, 2008 | 12:46 PM
discoknut's Avatar
discoknut
thanks I will make my way there.
Old Sep 8, 2008 | 01:35 PM
dchamberlain's Avatar
dchamberlain
This is the ICP. It is on the passenger side valve cover.
Old Sep 9, 2008 | 08:36 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I'd check the wiring and connector before assuming the sensor itself is bad. The "open circuit or short to ground" is key
Old Sep 9, 2008 | 08:47 AM
skoveng's Avatar
skoveng
On the '03 models I blieve the ICP is located on the high output oil pump cover located at the rear of the engine below the turbo on the left side. I think they moved it to the valve cover in '04.
Old Sep 9, 2008 | 09:37 AM
cartmanea's Avatar
cartmanea
Yeah, its in no-man's land under the back of the turbo in '03. I think most people change it blindly reaching up from underneath
DDPJ
Oct 4, 2014 06:51 AM
bismic
Jul 27, 2014 06:31 AM
gamaliel
Jan 7, 2013 08:33 AM
jtharvey
19
Apr 15, 2012 03:44 PM
fixnair
Mar 12, 2011 07:21 PM
