tune up difficulty
Old May 17, 2008 | 06:54 PM
RAMMAN4's Avatar
RAMMAN4
tune up difficulty
I did a basic tuneup on my 96 F150 302 today, cap, rotor, wires, and plugs. It took me almost 3 hours in my driveway to do this. The driver side was relatively easy compared to the rest. On the passenger side I was inventing new cuss words, but couldn't mutter them out loud because my 3 year old was running around. On the 3 and 4 cyclinders on the passenger side far back I actually had to take off the passenger side tire and reach in the fender well through a gap in the fender well to pull the plug wires off and the remove plugs. Is it normally this difficult to change the plugs for ya'll? BTW, it looked like this has never been done since my uncle bought the truck in about 97. Some of the gaps on the plugs were about 0.065 when they were supposed to be 0.044. On my ramcharger I can do this same work in about 1 hours time.
Old May 17, 2008 | 07:54 PM
Animalistic's Avatar
Animalistic
Welcome to the world of compact (cram it in there one way or another) compartments. I had the same problem with my rig and it is ready for a tune up again. Mine is older so I have a little more room but it is pretty bad. My wife has a '99 Durango with the 360. I can't even see the plugs (or the heads for that matter). I have even read here that you have to remove the intake manifold to replace the right valve cover gasket. Go figure.
Old May 18, 2008 | 07:51 AM
EPNCSU2006's Avatar
EPNCSU2006
Check the emissions label for the plug gap. I remember the newer trucks using a .056" gap.
Old May 18, 2008 | 07:56 AM
alz's Avatar
alz
Yeah, the label under the hood on mine says .052-.056.
Next time you do the plugs use a u-joint adapter on the plug socket, and then an extension. I can do them all in about 20 minutes taking my time.
Old May 18, 2008 | 08:11 AM
RAMMAN4's Avatar
RAMMAN4
I had to use a swivel and an extension on all of the plugs on the passenger side. I asked the person at autozone what the gap was. She said it was 0.044 and the haynes manual says ALL ENGINES 0.044.
Old May 18, 2008 | 08:16 AM
alz's Avatar
alz
There should be a sticker under the hood.
Old May 18, 2008 | 08:50 AM
str8racing's Avatar
str8racing
My haynes manual was wrong it's .052-.056, Did you put never seize on them when you put them back in?
Old May 18, 2008 | 09:51 AM
RAMMAN4's Avatar
RAMMAN4
Sure did. I learned that lesson long long time ago.
Old May 21, 2008 | 01:06 PM
jarod17's Avatar
jarod17
Strange. In my '96 I have no problem with the passenger side when pulling plugs. My problem comes from the driver side with the steering shaft getting in the way.
Old May 21, 2008 | 03:17 PM
RAMMAN4's Avatar
RAMMAN4
The 460 might be setup different on the passenger side than my 302.
Old May 21, 2008 | 06:29 PM
icrman's Avatar
icrman
Thats how I do mine, behind the tire, it sur beats trying to get around all the plumbing.
Old May 21, 2008 | 11:46 PM
TexasGuy001's Avatar
TexasGuy001
Mine isn't nearly that difficult with its 302. The passenger side is a bit tight but not that bad.
Old May 22, 2008 | 05:36 PM
str8racing's Avatar
str8racing
The first time you change the plugs always spray a couple times before. then coat with never seize.
Old Jul 15, 2008 | 11:45 PM
jarod17's Avatar
jarod17
Talking
Another thing you can do to make changing spark plugs easier is to replace your front clip with a fiberglass tilting front clip for about $2,000
May not be practical but the coolness factor would increase and make it a LOT easier to get to most anything on the engine
BAD RONALD
Aerostar
Sep 19, 2012 04:13 PM
dwill49965
1983 - 2012 Ranger & B-Series
Aug 26, 2009 03:40 PM
smuggler
Nov 26, 2005 02:16 PM
happyn98
Modular V8 (4.6L, 5.4L)
Jan 8, 2005 12:09 AM
