Offroad & 4x4
Another TTB bites the dust...
Old May 14, 2008 | 05:31 PM
ibleedblue1385's Avatar
ibleedblue1385
whats wrong with skull. man you people are negative.
Old May 14, 2008 | 05:33 PM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
i do belive an old member used to have the same avatar.....
Old May 14, 2008 | 05:36 PM
Truckin4life
Originally Posted by unrulee
I think a solid axle swap trumps BFG A/T's, and your TTB !!!
Yes... but I DIDNT buy the bfg's they came on the truck... I am buying 37's to go on, and then we will see how long the ttb lasts, i already know that it sucks, so why not break it and then do the sas...
While sas may trump bfg's and my ttb, it dont trump his body lift...
Lets not start anything over this... ok?
Old May 14, 2008 | 05:37 PM
Truckin4life
you could take it as being negative... But we look at it as being honest...
Like i said, i could make a mall crawler comment...
35" ish bfg's
body lift
nice shiny paint job...
but it seems your goin down the right trail
sas
iroks...
Hopefully ditching the dangerous body lift...
Old May 14, 2008 | 05:39 PM
Truckin4life
ibleedblue...
What axle did you use for the sas?
ibleedblue1385
I put the body lift on when i was like 17. No point in removing it, so its staying on. Im considering a entire write up of the entire swap here in the Offroad forum.
Old May 14, 2008 | 05:40 PM
ibleedblue1385
Dont be jealouse cus I paint my own stuff...
Old May 14, 2008 | 05:41 PM
Truckin4life
well did you atleast upgrade to grade 8 hardware?
Not tryin to be an azz but they can be real dangerous, espically when you start using cheaper hardware... Like whats usually sent with the kits...
also what engine do you got, and what have you done for gears?
Old May 14, 2008 | 05:42 PM
Truckin4life
never said i was jealous... yellow aint my thing anyway... my truck is nice and shiny sometimes too. when it aint covered in mud... The paint has actually survived quite well over the last 12 years....
Old May 14, 2008 | 05:44 PM
ibleedblue1385
The body lift has grade 8 yes. As for engine its a 5.0L HO. Heads ported & polished. B303 cam. Crane 1.7 roller rockers. Complete MSD. Edelbrock intake & carb. I built it about 4 years ago, it still runs good. My plans are either a FE 390 or 393W stroker. It still has 3.55's, but im putting 4.56's in this summer also. The axle is D44 from a 78' F-150.
Old May 14, 2008 | 05:49 PM
Truckin4life
good to hear on the body lift... bet that 5.0 has some troubles with the little 3.55's dont it... Why not a 60 though or even a 70?
Old May 14, 2008 | 05:53 PM
ibleedblue1385
I got the d44 front complete for $100. I dont plan on running bigger than 38's. If need be I can upgrade axle shafts and u-joints, no biggie. The 5.0 actually has the power. Couple friends of mine have chebbies with tbi 350's and 35" tires. One even has 4.56's. I can out run both of them.
Old May 14, 2008 | 05:56 PM
  #28
Truckin4life
alright... well i look forward to the write up...
Old May 14, 2008 | 06:01 PM
  #29
unrulee's Avatar
unrulee
I'm not trying to start anything, just poking fun, relax. I didn't even know that you had BFG's on your truck. That does make this a little funnier though .
Old May 14, 2008 | 06:09 PM
  #30
Truckin4life
yes it does actually... but as i say... the fastest way to bigger tires is to burn off the smaller ones... and well the bfg's dont grip anything at all... so powerslides on dry pavement is becoming easier and easier as each day passes.
ibleedblue1385
Offroad & 4x4
81
Mar 17, 2011 08:27 AM
ibleedblue1385
Offroad & 4x4
122
Sep 30, 2008 11:51 AM
ibleedblue1385
Offroad & 4x4
61
Aug 21, 2008 03:52 PM
ibleedblue1385
Offroad & 4x4
18
Jun 21, 2008 02:10 PM
ibleedblue1385
Offroad & 4x4
52
May 22, 2008 07:49 PM
