97 PSD Hard Start. Weak HPOP?
Old May 10, 2008 | 11:24 AM
aldridgec's Avatar
aldridgec
Helping with a 97 that is having a hard start problem. This will come and go. Sometimes for days it will be fine, then out of the blue it will need to be cranked extendedly for it to start. The ICP when it isn't starting is in the 300psi range, so it is certainly an oil issue. I've checked the basics, oil, level, leaks, cleaned the ipr. Haven't deadheaded the lines yet and checked bank to bank since it's hard to isolate when it happens but that is probably the next step.
The ICP has been low on this truck for a while, and I think it just needs a new HPOP it's got 215k on it. Yet, I haven't seen one act intermittently like this. It's got Baby Swamp injectors (150/146 iirc).
Thoughts?
Old May 10, 2008 | 12:07 PM
Neal 97 250's Avatar
Neal 97 250
Is the HPOP reservoir full when this happens. Next time check it to see. Sounds like it is draining down.
Old May 10, 2008 | 12:09 PM
Neal 97 250
Also I bought a pump from e-bay for $350 just have to watch for them to come up. International can get the pump for cheap also but they have a high core charge but that shouldn't affect you.
Old May 10, 2008 | 04:48 PM
aldridgec's Avatar
aldridgec
Yeah, I thought it was draining out too, but it was full. I think one way or the other it needs one, I was only seeing 2400 ICP on it a few months ago. Should be closer to 3000.
Old May 10, 2008 | 05:51 PM
RubberDuck's Avatar
RubberDuck
IPR o-rings.......all day long. Ask Tim for the international part #. Ford want's $45 for them. Seriously, I'd bet the farm on IPR orings.
Old May 10, 2008 | 06:52 PM
aldridgec's Avatar
aldridgec
Cool, give it a try. We took it out and cleaned it like I noted, but didn't use new o-rings since we didn't have them handy. Definitely the cheap things first. Are the o-ring kits I see on ebay any good?
Old May 10, 2008 | 08:44 PM
RubberDuck's Avatar
RubberDuck
I couldn't tell you about ebay rings. I wouldn't hesitate if they were alliant orings. Other than that, I wouldn't.
Old May 10, 2008 | 08:54 PM
tjbeggs's Avatar
tjbeggs
IPR O-Ring Kit (for when IPR valve replacement is not required)
(Ford) F6TZ-9C977-AN (F6TZ-9C977-AA?)
(International) 1825806C92 (1825806C91?)
They are definitely worth a short for $15 and an hours work.
Old May 11, 2008 | 12:59 AM
dinikin's Avatar
dinikin
Weak battery or worn out starter that draws alot of current might do that.
dougbrown
Jun 10, 2014 11:31 PM
keithwattles
Dec 11, 2011 11:44 PM
408w
Jun 6, 2007 09:20 AM
