p1280 code
Old Dec 8, 2011 | 12:22 AM
keithwattles's Avatar
keithwattles
p1280 code
I have read several threads in this and other forums concerning the p1280 error code. It seems that most people are pointing at the ICP. Some have said that if there is oil in the connection, the ICP is bad or going out and if you disconnect the ICP the engine will run properly. I have disconnected the ICP and my engine still wont't run. It "fires" but it immediately dies. Another thread said to check the oil level in the HPOP reservior. I haven't checked the oil yet but I don't understand how the reservoir could be low on oil if the engine isn't.
Any ideas why my engine won't run with the ICP disconnected?
Old Dec 8, 2011 | 08:40 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
You need to give us more information on your truck and what is happening. Did the engine just quit on you or does it just not start?
Old Dec 8, 2011 | 08:58 PM
keithwattles
p1280 code
I'm sorry. I was driving the truck, came to a stop sign. When I went to start off, the truck sounded like crap and died. I haven't been able to get it restarted since. I had it towed home. It fires but will not run.
Thanks for responding. Sure hope you can help me.
Old Dec 10, 2011 | 10:35 PM
powerstroke72's Avatar
powerstroke72
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old Dec 10, 2011 | 10:44 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Out of fuel? Not trying to be a smart a**....it's just that this very same thing happened to my wife earlier this week. If you heard her tell the story the truck completely fell to pieces in the middle of the road and all functions ceased. Unfortunately I was out of town when it happened. Luckily I had her check the simple stuff first and she was just out of fuel.
Check and see if you have any fuel in the bowl (filter/water separator)
Something to check...(I hope it's that simple...)
FYI...if all other systems are good, then the engine should still start and run with the ICP disconnected. It will throw a SES light but should start and run fine.
Old Dec 10, 2011 | 11:15 PM
keithwattles
p1280 code
You're right, I wish it was that simple. I have over a half tank of fuel. The bowl is full. and it won't run with the ICP unplugged. I also checked the oil level in the truck and it was in the operate area on the dip stick. I then checked the oil level in the HPOP oil reservoir and it was within an inch from the top of the reservoir. I then cleaned the ICP connector with contact cleaner thinking that since there was oil in the terminals, they could be shorted. That didn't work either.
Tomorrow I'm going to pull the IPR and see if ti is tuck. Hope that solves my problem.
Thanks for your input. I can't believe that only 2 people have experienced a P1280 code and solved it.
Old Dec 10, 2011 | 11:29 PM
Shake-N-Bake
Well, the PCM looks at ICP during the CCM test and if it finds values out of range then it simply ignores that sensor. It then will allow the engine to start but the IPR won't be allowed to change duty cycle unless the CPS comes online. If the PCM doesn't see the CPS then it shuts down the engine (which could be happening in your case).....however, your suggestion to clean the IPR is also a great choice. I would probably be doing the same thing if I was facing your symptoms.
What scan tool are you using? Do you see engine rpm while cranking?
Old Dec 10, 2011 | 11:32 PM
Bonanza35's Avatar
Bonanza35
Well another thought, what did you pull the codes with. Not all code readers are equal.
Theres alot of things electrical on these engines that will make it not run. First thing that comes to mind is the fuel heater in the bowl and I believe #30 fuse. CPS also amoung other things. Hopefully not a bad IDM, is it wet? I really hope you get it fixed and as you go down the list keep us posted that we mit help.
Old Dec 11, 2011 | 01:20 AM
keithwattles
p1280 code
Thanks for the additional things to check. I don't know the name of the scanner that was used to pull the codes. It belongs to the dealership thst my son works for. One of their mechanics used it on my truck. It actually pulled 6 codes with the p1280 coming up as a pending code. The mechanic said it came up as a pending code because it is a code that the PCM must see at least twice for it to be looged and since the truck died and I haven't been able to get it started again, he believes that that is when the first p1280 code was seen. The other major code that it pulled was a p1316 which is an IDM code.
I'll try cleaning the IPR and check all the fuses in the morning and let you know if I get it running.
Old Dec 11, 2011 | 06:44 AM
F350-6's Avatar
F350-6
P1280 often refers to a wiring issue with the ICP. If you have chaffed or shorted wires, or unplug the ICP, that is the code that trips.
Checking the IPR sounds like a good idea, but knowing the rest of those codes would be helpful. The P1316 is a much more important code to be chasing than the P1280. While the scanner was there and he pulled that code, did he buzz test the injectors?
Give us any more details you can remember, even if they don't seem important so we can try to help. Odds are fixing your P1280 code won't get the truck running.
Old Dec 11, 2011 | 04:07 PM
keithwattles
p1280 code
He did test the injectors with the scanner and they all operated with no problem. I'm going to go pull the IPR now. The other codes that came up are as follows p0276
p0344
p0603
p0703
p1000
Old Dec 11, 2011 | 05:53 PM
F350-6's Avatar
F350-6
p0344
p0603
p0703
p1000
Did he clear the codes, crank again and see what came back? P0344 just went to the top of the list. Without a signal, or a faulty signal from the CPS, these trucks won't run. Be sure to only use a CPS from Ford or International. Too many problems with the aftermarket ones.
Depending on what year your truck is, the tach bouncing while cranking can indicate a good signal from the CPS. Using a scanner to monitor RPM's while cranking will also indicate a good CPS. Some year trucks the tach won't move until the engine starts.
Old Dec 11, 2011 | 11:44 PM
keithwattles
He did clear the codes. I also replaced the CPS prior to him putting the scanner on because I had had this problem before and was sure thst would solve it. It didn't. The p1280 stayed as a pending code.
stilltruckinn
6.4L Power Stroke Diesel
Oct 15, 2014 02:15 PM
rocky1074
Jul 15, 2011 06:24 PM
qdrider01
Dec 21, 2009 03:10 PM
Dustmaster
15
Dec 16, 2008 04:59 PM
mtgrzlyman
13
Jul 19, 2005 10:28 PM
