fuel pump leaking
Old May 8, 2008 | 08:26 AM
brushfit's Avatar
brushfit
fuel pump leaking
could someone direct me to the best place for fuel pump purchase thats relatively cheap? live in boise area
Old May 8, 2008 | 09:32 AM
MagKarl's Avatar
MagKarl
Fuel pump replacement is a very common topic here, do a little searching and you should find lots of info and instructions. From what I understand, there is only one manufacturer for the pump, so it doesn't matter where you get it from, just call around and get the best price. I didn't know that when I did mine, wasted my money at the dealer.
Old May 8, 2008 | 09:43 AM
Robbgt's Avatar
Robbgt
I believe Carter is the pump I got and the only one for our truck. There available at autozone, although I'm in MA, so I'm not sure what's located in Boise. Pump will run you about $90.
Install directions are located here
https://www.ford-trucks.com/forums/5...ml#post3814892
There are a few other hoses etc. you may want to consider getting, part numbers located in that install post
Hope this helps!
EDIT: NOTE: the box may have a different brand on it, pull the pump out and "CARTER" should be stamped on it
-Robb
Old May 8, 2008 | 10:03 AM
Hussler's Avatar
Hussler
Got mine from Checker/Schucks/Kragen outlet. Was on sale for $75.00 but just checked and now they are going for $99.
Old May 8, 2008 | 11:02 AM
10bands's Avatar
10bands
Just did mine a week ago. Those instructions Robbgt posted are excellent. Bought mine at NAPA in Meridian for $110. Didn't check around for better price though. It's recommended that you heat and bend a 1 1/4" wrench to get the banjo bolt out but I didn't have a torch readily available so tried it without bending and it worked fine. Might have been a tad easier bent but it really wasn't a problem.
Old May 8, 2008 | 11:27 AM
Robbgt's Avatar
Robbgt
Good point on the wrench, I forgot to mention that. I think it was the same deal on mine, didn't even have to bend the wrench to make it fit on the banjo bolt. Just be sure that you're CAREFUL when you snug that baby up, obviously with a wrench that long there will be alot of leverage available. Just get it good and snug
-Robb
Old May 14, 2008 | 11:43 PM
brushfit's Avatar
brushfit
thanks a bunch for all the replies .......sorry didnt get back right away gotta work daylight till dark to buy fuel ! I have a 97 gasser but still love my diesel...didnt know the pump was so reasonable just need an afternoon now..thanks again
Old May 15, 2008 | 05:08 PM
WALJON's Avatar
WALJON
I just priced one at NAPA big dif in price compared to you fella,s down south $197.99
Old May 15, 2008 | 06:07 PM
Hussler's Avatar
Hussler
Just checked their online price and was quoted at $105. Disclaimer indicating in-store price may vary though.
God, I wish Napa would make a more user friendly Web site.
Old May 15, 2008 | 06:44 PM
Robbgt's Avatar
Robbgt
x2 man, sometimes it can be a real PITA!
-Robb
Old May 15, 2008 | 07:20 PM
WALJON's Avatar
WALJON
Yeah I,m sure the pumps price is adjusted by the store owner get this I priced a water pump as well and they want$229.67 for a reman and $246.14
and $14.00 for my core
All the other places I checked were around the same price (locally)
Old May 16, 2008 | 07:33 AM
brushfit's Avatar
brushfit
im seriously thinkin bout new skins for the mountain bike..
topscrt
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Mar 3, 2014 10:37 PM
bassproguy07
Aug 20, 2006 09:13 AM
shazam
Feb 15, 2002 12:12 AM
redbronco2
Bronco II
Mar 22, 2001 11:58 PM
proeliator
Jan 1, 2001 03:29 PM
