Bronco II Ford Bronco II
Fuel Pump
Old Mar 9, 2001 | 05:30 PM
redbronco2's Avatar
redbronco2
Fuel Pump
Old Mar 21, 2001 | 10:42 PM
pee wee's Avatar
pee wee
Fuel Pump
Sometimes my fuel pump runs after the key is turned off. What causes this? Fuel relay stuck? Sometimes it is just a second or two sometimes after the rig is cold and only run for say a minute or so it will stay running as long as 10-30 seconds after key is off. If it is the relay where is it? It is a 1990 Bronco II
Old Mar 22, 2001 | 11:58 PM
babybroncoii's Avatar
babybroncoii
Fuel Pump
ive got the 88 with the 2.9 and my fuel pump relay is located on the passenger side just behind your battery. it is a green relay. when my fuel pump relay went, i had trouble starting my truck because it wouldn't build up fuel in the fuel rail. good luck
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
