eletric fuel pump
Old Feb 9, 2002 | 12:26 PM
shazam's Avatar
shazam
eletric fuel pump
Old Feb 14, 2002 | 05:11 PM
lowcountry's Avatar
lowcountry
eletric fuel pump
I am looking at converting over to an eletric fuel pump reason being I don't get enough fuel out of the mechanical when I need it off-roading. The ? is do I need to run a return line back to the tank or not.
I am running a 74 f100 with a 390 and holley 600 looking to upgrade to the new truck avenger soon.
Thanks
Scott
LowCountry Swampers
MIOBI
Old Feb 14, 2002 | 06:00 PM
x_FordMan_x's Avatar
x_FordMan_x
eletric fuel pump
I am running a holley electric pump and i don;t have a return line. it runs real nice but i havn't took it off roading yet. good Luck
Ford Man
Old Feb 14, 2002 | 06:52 PM
Mil1ion's Avatar
Mil1ion
eletric fuel pump
There are different type electric pumps.
Some are High Volume /High pressure
Low volume /Low pressure.
Most carbureted systems the pump pressure is 7-9 psi
In EFI it's around 45 Psi
Dennis https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=1733&.jpg
Please Don't Ask Me Any Tough Questions As:
"I'm Saving My Memory For When I Develop Alzheimer's"
78 F-150 429CJ,Silver
w/Explorer Pkge.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon
Old Feb 14, 2002 | 08:45 PM
FOMOGO's Avatar
FOMOGO
eletric fuel pump
You do not need a return line for this application. On electronic fuel injection set ups this is neccessary. I have a 67 F100 in addition to my 79. The 67 has a 390 like yours with a set of 427 medium riser heads and intake. I have a 700CFM Holley with a mallory electric pump. My truck is not for off road use either, but i can't see where that should make any difference. FOMOGO
Old Feb 14, 2002 | 09:23 PM
michael 3807's Avatar
michael 3807
eletric fuel pump
you might want to think about mounting the pump close to the tank as possible and if you have 2 tanks mount the pump as close to the output side of the tank switch as possible the reason is electric pumps like all pumps will push fluid alot better than it will pull it hope this helps
mike l
Old Feb 14, 2002 | 10:59 PM
masterbeavis's Avatar
masterbeavis
eletric fuel pump
More food for thought;
-oil pressure cut off switch, or crash switch. This is to shut off pump automaticaly if something bad happens like the oil pump seizes, -the motor dies, you get into an acciedent....
-power relay. This will keep the load off your old trucks wiring system, will be one less gremlin cause
-large high flow filter. Your truck is over 26 years old, there is no telling what kind of crap is in the tank that will foul up your new fuel pump. Place this directly in front of the pump by the way
-new fuel lines. At the very least replace the rubber ones. Use tranny cooler lines, I am told they have better resistance to MTBE(A neoprene inner lining maybe??), and other crap that is in gas that ruins fuel lines. This is cheap insurance. MAKE SURE THEY DONT RUB anything, they need to be properly insulated against cuts and abrasions. blah blah blah
This is the start of a good and safe electric fuel pump setup. When all is said and done, you will have probably spent about $90 not including the pump($50 ish) to do the upgrade, and maybe about 3-4 hours total time to do all of the work. Have fun
Tony
'73, '74, '77 F250
Old Feb 15, 2002 | 12:12 AM
michael 3807
eletric fuel pump
thanks tony i forgot about the filter that is a big must good thinking
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
