Back door speakers?
Old May 5, 2008 | 05:55 PM
SUPERDUTY_untouchabl's Avatar
Back door speakers?
Do the back doors have the same oval speakers as the the front? I figure I would ask first so I dont have to tear the door apart to find out. They arent as easy to get to as the front. Reason being I have a pair of $200 six and a half circle speakers. I may just have to build me a custom box and mount them some were. Anyone have any ideas?
Old May 5, 2008 | 06:24 PM
black04lariat's Avatar
black04lariat
I have 6.5's in my rear doors (SCAB). Assuming that the speaker in other models of the truck are mounted directly to the door...They will fit, I don't remember if I had to trim the metal at all, I don't think I did. Just take a piece of sound deadner, cover the factory hole, the make a new circle big enough for the 6.5 in the deadner. You will need to make new holes to mount it in there.
Old May 5, 2008 | 06:55 PM
So the backs arent the ovals like the front are? I was going to try and make em fit in the front but I would have had to cut quite a bit to make it fit.
Old May 5, 2008 | 07:16 PM
black04lariat
The rears are ovals as well. But the fronts are mounted to the door panel in essence...whereas the rears are mounted flush to the inner door itself. I wish I had a picture of mine and how I did it to show you..
Old May 5, 2008 | 07:21 PM
Ill figure out how o get them in there if theres room. Now I got to figure out how to get them door panels off. On the reg cabs the speaker cover doesnt pop off like the fronts do.
Old May 5, 2008 | 07:47 PM
Ok I just went out there to take a gander at it. Takeing those back doors off is the scariest thing I have ever done. Its all tabs not a single screw and you have to pull extremely hard to get them off. I think I know what you are saying what you did black. But did you only put 3 screws back in? Thats the best I could get mine was 3 holes on the metal.
Old May 6, 2008 | 03:39 AM
mitch150's Avatar
mitch150
Not sure what a regular cab's back panels are like, but on my scab the back door panels just pop UP and off after removing a few screws, like the front doors, and the speakers were exactly like the front,though I think u can alter the size.
Old May 6, 2008 | 05:32 PM
Well I put them into today just drilled some holes and wired it up. It sounds 10x better than the stock ones sounded. Now I need front ones because the back ones make the front sound like crap now.... when will it ever stop?
Old May 6, 2008 | 09:45 PM
irishammer's Avatar
irishammer
When your wallet is empty....LOL
sparks717
Apr 25, 2014 02:04 PM
Excursion123
Mar 23, 2013 09:50 PM
97rangerguy
Dec 7, 2004 05:17 PM
Ford35003
1983 - 2012 Ranger & B-Series
Sep 2, 2004 04:09 PM
greymule
Oct 11, 2002 01:42 PM
