need help again -- leak
Old May 6, 2008 | 01:52 PM
verumlike's Avatar
verumlike
Originally Posted by zx250
Don't want to dispute a big diesel guy, but these trucks are very prone to oil leaks and most of the time it will run out of the back of the engine valley, down the back of the engine and out of the inspection cover on the tranny. It looks very much like a rear seal. The rear seal does fail, but it is so rare that most of us tend to forget about that. Climb up on top of you engine with a good light. Remove the plastic cover over you fuel bowl so you can see, Look down into the valley(center) of the engine. I'm betting you will see oil puddled up down there, probably in the back, under the turbo. If so, you have a top side oil leak that is showing up on the bottom and not a real seal.
were 1000% sure it is not oil though , it looks nothing like oil, I am however going to pop the hood and attempt go get up there and have myself a look. I appreciate the help man!
Old May 6, 2008 | 01:55 PM
Smokin''s Avatar
Smokin'
Smokin
Originally Posted by verumlike
OKAY UPDATE --- a big diesel guy over in my neighborhood told me that its the rear main seal (main/mane ?) He said its not a huge issue unless its leaking badly in which case we gotta get to the transfer box and deal with it ! sound correct?
So it turns out it was an oil leak? I read somewhere that the rear main seal is a rare thing to leak on the 7.3....
Old May 6, 2008 | 01:57 PM
zx250's Avatar
zx250
Of the next Riffraff East
If it not oil then it's not a rear main. If it tranny fluid, it could be a pump seal or if its leaking out of the back of the tranny, a rear seal. Tranny fluid has a very unique smell and should be reddish in color.
verumlike's Avatar
verumlike
geuss ima hop up there and look for some pooling then .
Old May 6, 2008 | 02:00 PM
Smokin''s Avatar
Smokin'
Smokin
Let us know how the weather is up there.
Old May 6, 2008 | 02:02 PM
verumlike's Avatar
verumlike
Roger that, ill get in there in about an hour or so.
Old May 6, 2008 | 02:12 PM
bdrummonds's Avatar
bdrummonds
It could possibly be a fuel bowl drain oring leak that has disolved some dirt and grease to turn it the blackish color. Although if it was the fuel drain orings I would think you would smell diesel every time you walked past the truck. Well maybe not since the dang engine is well above nose heighth.
Old May 6, 2008 | 05:12 PM
verumlike's Avatar
verumlike
Its actually right at nose heighth, id probably smell it easier.
Old May 6, 2008 | 05:33 PM
totin_tools's Avatar
totin_tools
I am just surprised that in Paso you dont get pulled over for being that high. My buddy used to have lifted trucks with 44's and we'd get pulled over all the time, for bumper heights.
Old May 6, 2008 | 05:46 PM
verumlike's Avatar
verumlike
i avoid cops, but if one drives by i dont usually get hassled .. i have been before but not lately.
Old May 6, 2008 | 06:45 PM
zx250's Avatar
zx250
Do you know what is leaking yet. Can you post a picture of the what you are seeing when you WALK under your truck?
Old May 6, 2008 | 07:22 PM
verumlike's Avatar
verumlike
The leak is coming from the transfer box (confirmed)
pilgrimbizket
Nov 16, 2013 02:05 PM
autx790
1978 - 1996 Big Bronco
Feb 18, 2007 07:22 PM
cade
2004 - 2008 F150
Jul 21, 2005 06:12 PM
gcreed
Aerostar
21
Mar 7, 2005 08:50 PM
