question about 'TFI module'/'ICM'
Old May 3, 2008 | 10:35 AM
macmillanracing's Avatar
macmillanracing
I have a '92 F150/5.0 that has a dead TFI module or ICM (call it what you will). Mine is the remote mount model that goes on the firewall. On the Ford Motorcraft website, there are 2 different listings for either the firewall mount one or the distributor mount one. But, every parts store I've been too only has the distributor mounted style. I already pulled mine out of the truck, and it looks almost like it's just the distributor mount one attached to a heat sync. Am I right in thinking I can just take mine apart and swap the actual module part? Thanks.
Old May 3, 2008 | 10:57 AM
BChance's Avatar
BChance
Is your old one a Ford E8 DZ-12A297A?
Last edited by BChance; May 3, 2008 at 10:59 AM. Reason: cuz ford part #s turn into smileys...
Old May 3, 2008 | 02:47 PM
macmillanracing
the existing one is a Motorcraft E7DF-12A297-A1A, close but not exactly the same. I actually did get a new module for a distributor mount and it interchanged with the old one perfectly, haven't tried it out yet. I guess I'm just hoping the guts of the modules are the same so I can get my truck running. Thanks.
Old May 3, 2008 | 03:42 PM
Creel's Avatar
Creel
Yes. Make sure you use the dielectric compound that should have came with it, or your new one won't last long.
Old May 3, 2008 | 04:38 PM
BChance's Avatar
BChance
Activant Cover-to-Cover
MOTORCRAFT® FULL LINE CATALOG OF PARTS FOR FORD, LINCOLN OR MERCURY VEHICLES
yup, same same...
Old May 3, 2008 | 05:49 PM
macmillanracing
cool, thanks guys
Old May 29, 2011 | 01:28 AM
w6pea's Avatar
w6pea
On what side of the firewall or engine compartment i it located at.
Tim Hodgson
170
Dec 29, 2025 02:44 PM
one_bolt_short
13
Jun 6, 2017 11:52 AM
Motorhead-42
80
Jul 27, 2016 02:30 PM
lawsonej
May 31, 2016 07:40 AM
vaughn1977
Apr 13, 2007 11:33 AM
