where the hell is my fluid going??....
Old May 1, 2008 | 11:51 PM
bad_habit59's Avatar
bad_habit59
Someone on here helped me diagnose my heater acting up last week, it was due to low rad fluid. Now I keep having to top it up. I don't have a puddle under my truck as far as I can tell, and I just changed the oil and it didn't have any rad fluid in it (it should be white and foamy if there is water in it, right?)
So where the hell could it be going?...
Also, when I filled up my rad overflow today I had some rusty looking film floating on top of the fluid as it rose. Now that I think about it, it is probably oil based if it is floating. Where is this coming from??
Old May 2, 2008 | 12:42 AM
johnboy427's Avatar
johnboy427
One of the tanks on my radiator leaks a little on the front side, I guess it is a slow enough leak and it is hot enough to where no fluid ever shows up on the ground its just really crusty at the leak and hard to see behind the a/c heat exchanger. I would look the system over really good because after all it has to go somewhere. Check the exhaust for white smoke too you can crack a head although uncommon that leaks into the combustion chamber and it just burns off no milky oil and no leak I had a 1990 mazda B2600i that did that and it was chocking down a gallon a week before it got bad.
-Johnboy
Old May 2, 2008 | 05:44 AM
ri_truck_guy's Avatar
ri_truck_guy
Sometimes it takes a little bit of circulation to get all the air out the cooling systems when they've been emptied and refilled. If you aren't getting white smoke, the oil is lean, and is runs ok I wouldn't worry too much about it. It doesn't take very much oil to make a film on top of the fluid. It could easily come from a funnel used to fill the system if that same funnel has ever been used for oil ar trans fluid, even if it looks clean.
Old May 2, 2008 | 08:57 AM
quicklook2's Avatar
quicklook2
check water pump weep hole.
Old May 2, 2008 | 11:15 AM
guitarnik's Avatar
guitarnik
when the truck id running, put your hand behind the tailpipe and if it gets damp or moist with water you might be leaking into your heads somewhere. thats what happend to mine.
Old May 2, 2008 | 02:30 PM
qman's Avatar
qman
If you have a small puff of white smoke coming out the tail pipe that vanishes quickly, then it's leaking into your heads.
I had a problem with loosing coolant and it turned out that I needed a new radiator cap. I'd fill it up and then I'd smell coolant when I shut it off. One day I opened the hood and it looked like the stuff was oozing out from between one of the tanks and the core. I figured the radiator needed to be rebuilt. For the heck of it I bought a new cap and now all is well. My guess is that the old cap was letting the coolant from the overflow bottle into the radiator but not back out. Now I don't have a problem.
Old May 2, 2008 | 04:01 PM
quicklook2's Avatar
quicklook2
use a pressure checker to test cooling system.
Old May 2, 2008 | 08:19 PM
05chop's Avatar
05chop
Check the injector coppers they are below the injectors
SmittyVIP
Jan 21, 2013 11:22 PM
marks500
1983 - 2012 Ranger & B-Series
May 6, 2012 01:42 PM
broboon525
Oct 13, 2010 09:20 AM
rpokorny
Aerostar
Jul 7, 2004 12:02 PM
fordboy390
Oct 25, 2001 07:56 PM
