help with trans
Old May 2, 2008 | 08:55 PM
chaosforge's Avatar
chaosforge
help with trans
i have just bought a 1988 ford f150 with a 302 in it and my auto trans will not shift above 2nd gear i took off the pan changed filter and fluid then in the bottom of the pan i found a small hard plastic wite plunger with a o ring on it where dose it go
Old May 2, 2008 | 09:18 PM
graybird78's Avatar
graybird78
that little white plunger is from the factory assy line to plug up the dipstick hole . when the tube is installed the plug is pushed into the pan.sounds like trans has never been serviced.if it had the plug would have been discarded when trans was serviced.
Old May 2, 2008 | 09:20 PM
chaosforge's Avatar
chaosforge
then why wont the truck shift out of second and plz dont tell me its got to be rebuilt
Old May 2, 2008 | 09:39 PM
graybird78's Avatar
graybird78
was their any metal shavings in the pan? did the fluid have a metallic look to it? if your answer is yes to both questions then the trans needs rebuilt.
Old May 2, 2008 | 09:47 PM
chaosforge's Avatar
chaosforge
no the fluid is burnt and brown but no metal
Old May 2, 2008 | 09:52 PM
chaosforge's Avatar
chaosforge
it shifts from first to second easy but wont go further
wedge542
Jun 27, 2017 10:31 AM
02expy
May 22, 2014 10:44 AM
neilc88
Modular V10 (6.8l)
May 31, 2013 09:13 AM
old farmer
May 21, 2011 11:11 PM
robjs111
1997 - 2003 F150
Apr 1, 2011 08:19 PM
