4-speed bellhousing
Old Apr 30, 2008 | 10:24 AM
samickguy15's Avatar
samickguy15
4-speed bellhousing
What's the difference between the D9 and E4 bellhousings? I'm needing one for an '86 which had the aluminum E4, but I would prefer to have the D9 if it will work...Anybody?
-Aaron
Old Apr 30, 2008 | 02:11 PM
samickguy15
I'm having one hell of a time deciphering stuff...
I've got access to an E4TA-7505 and a D9TA-7505. Supposedly both big block bells. I called my Ford parts guy and he said the E4TA-7505 is for a small block...
Help?
Old Apr 30, 2008 | 03:53 PM
85e150's Avatar
85e150
Numberdummy may be by to sort this out. Or you can PM him.
OK, now I'm out to prove how little I know (again) so here's my wag.
D9 = 79 as in 1979
E4 = 84 as in 1984
TA = 351
The rest is the bell housing code.
Look at this chart and note the numbers given for 351s.
Bellhousing ID Chart
But like I said, ND has the books and the right answer.
Old Apr 30, 2008 | 06:40 PM
76 F-150 390FE's Avatar
76 F-150 390FE
the E4 should have a hydraulic clutch and the D9 will be mechainical from 84 on they used hydraulic clutches
Old May 2, 2008 | 02:21 PM
85e150's Avatar
85e150
Forgot about this site:
Kelly hotrod - Ford Engines Page 4
The "T" is for "truck", the "A" is for "chassis"
The 7505 must specify which engine, but I'm not sure.
Old May 2, 2008 | 03:26 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford: The group number shown in parts catalog illustrations is also the basic part number.
7505 is the basic Ford part number for a bellhousing = all Ford bells from 1.3L's thru 534's.
Add the prefix & suffix for a complete casting / engineering / part number.
The engineering numbers posted for the D9 & E4 bells are not complete, making extra work for this long suffering FTE member, who researches & types this *&(^%^ for free.
D9TA-7505-CB = 351M/400 (1980/82) 1977/79 was D7TA-AD
E4TA-7505-DA **or** E4TA-7500-EA = 300 / 302 / 351W (1984/ ) 7500: 7505 is not the only engineering number used for bells.
There are OTHER E4TA marked bells for 460's / 6.9 diesels / 2.8 V6's.
And...Not ALL the engineering numbers are shown in parts catalogs.
LOOK CLOSE = BE CAREFUL = there's also E47A markings. The 7 could mean a Aerostar/Ranger/Bronco II/F100/350/Econoline/passenger car.
Deciphering engineering numbers is a PITA. Thankfully, casting numbers cannot be cross referenced to part numbers!
Old Apr 2, 2015 | 11:37 AM
mustang81's Avatar
mustang81
did a top loader will fit on that bellhousing?
D9TA-7505
Old Apr 2, 2015 | 03:34 PM
mustang81's Avatar
mustang81
Old Apr 9, 2015 | 01:11 AM
RichS2659's Avatar
RichS2659
As that bell housing fits the 351M/400, then it fits the T-18/NP-435 truck 4 speeds, as the 351M was only used in trucks. Compare the T&C toploader 4 speed with the T-18 pattern to see if it will work.
Old Apr 9, 2015 | 01:32 AM
mustang81's Avatar
mustang81
Yes it fit 351m 400 429 460
Ricardo Chambers
Jun 7, 2017 07:54 PM
dnkensinger
41
Aug 23, 2016 08:56 AM
rattrucker
Sep 29, 2013 10:48 PM
1994F2507.3L
Oct 28, 2010 10:40 PM
mark123456
May 7, 2002 01:18 AM
