bellhousing i.d.
Old Jun 3, 2017 | 07:22 PM
Ricardo Chambers's Avatar
Ricardo Chambers
bellhousing i.d.
I just bought this bellhousing.
Can someone recommend a transmission?
I would use it with a '49 H flathead 6
thanks
Old Jun 4, 2017 | 09:04 AM
38 coupe's Avatar
38 coupe
That is a passenger car type bell. Ford passenger car transmissions from 49-64? should bolt onto it. Ford truck light duty three speed transmissions from 53-64? should bolt onto it. I'm not sure of the change over year for Ford wide pattern transmissions. If you find a dual pattern transmission I think the inside pattern still bolts to this bell.
A different concern is the depth of the bell. That looks deeper than my memory of Ford flathead 6 car bells. Hopefully I am wrong.
Old Jun 4, 2017 | 02:39 PM
Ricardo Chambers
Fred,
It was an ebay item, advertised as for a 6.
Is it the kind of bell that would take a Tremec 5 speed?
thanks
John
Old Jun 4, 2017 | 05:03 PM
Mixer man's Avatar
Mixer man
With all due respect to EBay, it's been my experience that some EBayers don't have a clue what they're selling and try to fake it.
Old Jun 4, 2017 | 07:07 PM
Ricardo Chambers
I hope this outfit would know
http://mobile.dudasite.com/site/rpmc...cted=true#3024
Old Jun 4, 2017 | 07:35 PM
Mixer man's Avatar
Mixer man
Originally Posted by Ricardo Chambers
Yep, and I can personally vouch for them. I have purchased parts for my F-6 COE there.
Old Jun 5, 2017 | 05:11 AM
Ricardo Chambers
that is kinda the "read" I got from looking at their web site.
Anyway, parts hunting for 70 year old Fords has proven to be "stimulating".
Here is a photo of a the bell I bought.
Comparing it to an 8 bell photo (from Wilcap, another good outfit, I assume?)
There are some subtle differences on the starter plate side, but the transmission
pattern side looks like i can bolt up T-5s and several years of Ford trans with a
1 1/16" input shaft,
The interesting thing is the starter plate from the '49 engine I'm concentrating on fits the '47 engine I just aquired, so maybe I just created a "back up" engine?
Old Jun 7, 2017 | 06:36 PM
Ricardo Chambers
the rust clashes with the blue
but all the holes line up!
about 5 1/2" from flywheel to transmission mount.
Old Jun 7, 2017 | 07:22 PM
38 coupe's Avatar
38 coupe
49-51 passenger car bell for sure. The clutch is a push from the front instead of the twist from the side that the 32-48 cars and 32-52 trucks use. Most adapter plates I have seen are set up to bolt to the 32-48 cast in bell housing. That is duplicated by using the appropriate 48-52 truck bolt on bell. I have no idea what the front of a Tremec 5 speed looks like so I can't help you there.
Old Jun 7, 2017 | 07:31 PM
Ricardo Chambers
I think you're right
My only hope is that there is one out there.
Another question, were car 6 trannys different from car V8 trannys?
Old Jun 7, 2017 | 07:54 PM
38 coupe's Avatar
38 coupe
No, starting in 1949 and lasting through at least 1954 the V8 and 6 motors used the same transmissions. The only exception during the remaining flathead years was 1951 when you could get an automatic behind the V8 but not the flathead 6.
64fordf100292
15
Sep 10, 2011 03:19 PM
oldiron73
Aug 26, 2010 06:17 PM
Marco Venegas
Apr 14, 2009 12:10 AM
piperig78
Dec 1, 2004 10:34 PM
F-750pickup
Dec 17, 2003 12:26 AM
