460 Bellhousing compatibility
Old Mar 5, 2002 | 06:02 AM
mark123456's Avatar
mark123456
I have an 85 f250 4X4 with the 6.9 diesel and four speed tranny. I want to replace the diesel motor with either a 460 or a 400.
My question is this:
Is a 400/460 bellhousing the same as the diesel bellhousing?
Thanks,
Mark
Old Mar 5, 2002 | 09:46 PM
merc460's Avatar
merc460
The 6.9/7.3 use a adapter plate to mate the engine to the 400/460 bellhousing pattern Eric
Old Mar 11, 2002 | 01:12 PM
dablack's Avatar
dablack
So does that mean the I could pull a 5 speed or a E4OD from a modern diesel and "bolt" it to my 74 460? I know the E4OD needs a computer and I know it would take lots of mods to run the 5 speed, I'm just asking about it being the same bolt patern?
Austin
Old May 3, 2002 | 11:31 PM
WC76TX's Avatar
WC76TX
>bolt patern?
>Austin
no guys it don't work I tried to match up a 1985 6.9 diesel clutch houseing to a 429 it looks real close but it does NOT work!
Will
Old May 4, 2002 | 12:58 AM
merc460's Avatar
merc460
Intresting what part did not work I have had several of these tranny out for clutch jobs and they look the same bellhousing wise, but I never had a chance to try and fit them against the 460 Eric
Old May 4, 2002 | 03:56 PM
WC76TX's Avatar
WC76TX
Well Eric it looks the same until you put them together, the bolt pattern is a little diffrent and the dowel pins are biger. the top too bolts apear to be in the same place as 460 but the others don't line up there was something else too but it was a year ago and don't remember what else but it is diffrent.
Will
Old May 6, 2002 | 11:56 PM
merc460's Avatar
merc460
Oh well it you win some and you loose some Its to bad that it won't work but we cannot stop with thinking up good and wonderful ideas
Eric
Old May 7, 2002 | 01:18 AM
Superdave's Avatar
Superdave
DrZoom
WTB - Parts & other
Jul 19, 2016 03:06 PM
George Fletcher
Aug 16, 2015 07:01 AM
lance65
WTB - Parts & other
May 27, 2014 09:28 PM
rattrucker
Sep 29, 2013 10:48 PM
F350moneypit
Aug 18, 2013 01:50 PM
