Sponsored by: Auxito
Tips for storage.
Old Apr 28, 2008 | 10:37 AM
Scout Chris's Avatar
Scout Chris
Tips for storage.
So my Brigade is making our rotation to the National Training Center in Ft. Irwin California next month for 28 days. Any tips for storing my 2003 Supercrew 5.4L? It's a 4x2, I am not sure if I should drain anything or what? I will be at NTC from May 17 to June 15. Truck will not be being started and stored on a lot on Ft. Riley. Thanks for all the help.
Old Apr 28, 2008 | 11:21 AM
ground_zero298's Avatar
ground_zero298
For 28 days? Fill up the tank and let her sit. I've let mine sit for way longer then that.
Also stock up on some cans of chew and a couple cartons of cig's. I've sold them for as much as 12.00 a pack. You might not need them but you can make a killing on them about the third week your out their. Also, a good pair of googles, mp3 player with patchcord to hook into the com system, and some ramen noodles. Put paper in the end of the fifty, fire no blanks, keep your 16 in a plastic bag. GL out their, be safe and watch out for the waddies. If you see a black cloud comming bundle up as quick as you can. P.S. rattle snake makes a real good dinner compared to MRE's, try to runum over by the head. Leave no food out at night, the coyotes are mean out their. Almost as mean as those 10 lbs redwing blackbirds.
Old Apr 28, 2008 | 11:22 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Keep the gas tank as full as possible to prevent condensation from building up inside it.
If you are really ****, you could put all 4 corners on jackstands to relieve the tires.
It's only a month's time...it will be fine like that....anything else would be "overkill".
Old Apr 28, 2008 | 12:15 PM
Bobby82490's Avatar
Bobby82490
The most i would do is throw in a bottle of Sta-bil, depending on how old the gas is now.
Old Apr 28, 2008 | 02:10 PM
monckywrench's Avatar
monckywrench
When I deployed I left a set of (good) jumper cables hidden under the seat. My rides always started, but saved other folks hassle by helping them out.
Old Apr 28, 2008 | 03:35 PM
Club Wagon's Avatar
Club Wagon
Might also try 1 of the solar cigarette lighter battery chargers. These are great for a trickle charge to maintain a full battery charge. Alarms, clocks, stereo memory all draw current-some disconnect the battery or add on/off switch. I also got a dinky solar ventilator that you run the window up on to hold on top edge of door glass. That tiny fan will circulate air & help lower temp inside when I park in the sun.
Old Apr 28, 2008 | 03:40 PM
avator's Avatar
avator
BEEN THERE, DONE THAT and GOT A TEE-SHIRT for my troubles....
all good ideas..... for being in Ft Irwin, that is.... not much to do for the truck. it will be fine to sit a month.
thanks for your service!!
Old Apr 28, 2008 | 04:33 PM
triton_2002's Avatar
triton_2002
Disconnect the battery, or take it out if you got a place to store it. Just makes it a little harder to steal.......
Old Apr 28, 2008 | 08:58 PM
jimm66's Avatar
jimm66
Sta-bill very good idea.
Old Apr 28, 2008 | 10:03 PM
Scout Chris
Thanks
Thanks for all the help- this is my first truck and very nice, so I m overly concerned about it! The only other thing I am worried about is hail damage from the Kansas storm season. Anything you all recommend to put on the truck to protect against that? It will be outside in the deployment lot-uncovered.
Thanks again for all this help- I love this site.
Old Apr 28, 2008 | 10:45 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Nothing you can really do for the hail. Try to park under a tree if possible.
Sta-bill is also not neccessary. Gas doesn't go bad for at least 1.5 years...
Old Apr 28, 2008 | 11:00 PM
galaxie641's Avatar
galaxie641
Agree with the above, my Galaxie has sat for a lot longer with no problems. A month is nothing for a vehicle to sit. If it is going to be out in the sun maybe buy a windshield cover thing to keep the sun off the dash.
Old Apr 28, 2008 | 11:15 PM
mjunk1's Avatar
mjunk1
Thanks for serving - first of all. We appreciate everything you do.
I always put a moisture absorber in my boat over the winter - might not be a bad thing to add. It just sits in your cab and will soak up the extra humidity and such so it doesn't seem so stale after sitting there so long.
You probably need to decide whether to close all the vents or leave them open - again it will effect the humidity in the cab. Guess I could see both ways - open for air circulation, closed to reduce humidity.
Don't leave any crayons around - they flat out melt!
Old Apr 29, 2008 | 06:48 AM
Spotty's Avatar
Spotty
My Mustang sits from Halloween until end of April. I put a full tank of gas in it before I store it. When it's time to start it up, cranks about 2 times and comes to life. Fuel injection has helped remedy a lot of "storage" problems in newer vehicles. A month is nothing. I have stuff around here that sits longer than that with minimal gas in it.
Spotty
Old Apr 29, 2008 | 08:22 AM
ground_zero298
If your worried about hail a cheap foam matress cover, one of those 2" thick ones under a car cover should work. I have one in the barn I use when we get hail storms.
army350
6.7L Power Stroke Diesel
Jun 13, 2012 11:13 AM
skunktruck
Kansas Chapter
46
Mar 22, 2009 03:37 PM
BigF350
50
Sep 12, 2006 03:17 PM
irwin51
1978 - 1996 Big Bronco
Dec 1, 2003 10:49 AM
Riley_7.5
Exhaust Systems
May 10, 2000 02:04 PM
