Sponsored by: Auxito
Code P1451. What to do?
Old Apr 23, 2008 | 07:16 PM
Stangfire's Avatar
Stangfire
2003 F150 XLT 5.4L 60,000miles
My truck is throwing code P1451. It came on 3 days ago. One week before that the check fuel cap light was on. I disonnected the battery and the fuel cap light went out but now the check engine light is on.
What is it and how do I fix it?
Thanks.
Old Apr 23, 2008 | 09:19 PM
Ultramagdan's Avatar
Ultramagdan
This one might help you: https://www.ford-trucks.com/forums/7...hat-is-it.html
Old Apr 24, 2008 | 07:34 AM
Stangfire's Avatar
Stangfire
"P1451 EVAP Control System Canister Vent Solenoid Circuit Malfunction"
Apparently it's an electrical problem in the Canister Vent Solenoid Circuit.
Where can I find the canister vent solenoid?
I'll check for broken wires and bad connections.
Old Apr 24, 2008 | 09:15 AM
projectSHO89's Avatar
projectSHO89
It is located on the vapor canister, under the bed.
Steve
Old Apr 29, 2008 | 07:33 AM
Stangfire's Avatar
Stangfire
The red wire going to the Canister vent solenoid was broken half way up the harness. I spliced in a new piece.
I drove the truck around and turned it on and off but the light never went off. I disconnected the battery and the light went off. I then drove around turning the truck on and off 4-5 times and the light has not come on yet.
Hopefully it stays off.
Old Apr 29, 2008 | 08:51 AM
projectSHO89
It probably will as the broken wire would directly cause that error.
The system may take a few weeks to re-run all the on-board monitors, several of which have tight entry requirements in order to run. Since that electrical fault has been cleared, there are now additional monitor testing that may be performed, so all the results may not be in for days or even weeks.
Steve
splatee
Apr 19, 2018 01:19 PM
lgeiger13
Modular V8 (4.6L, 5.4L)
31
Jul 22, 2016 10:53 PM
86capriASC
1997 - 2003 F150
13
Aug 7, 2010 10:48 PM
paulmdahle
1983 - 2012 Ranger & B-Series
Jan 23, 2009 02:57 PM
BURNSTOUGHFORD
1997 - 2003 F150
Jun 25, 2008 06:48 AM
