1965 F100
I posted a pic in my gallery, it's the only oneWhat I need is, what I'm assuming is a plastic sleeve or insulator that prevents the horn from continually honking.
When I put the spring brush assembly in the shaft it will honk the horn whenever I turn the wheel.
I live in the DFW metro area...I NEED a horn!
If your horn is honking continuously, you probably need the rubber "spring" or insulator that is underneath the plastic horn ring retainer on the horn ring. Remove the 3 screws that hold the retainer to the horn ring and you will see what i am talking about.
Hi fitch. I am cornfused? I have a plastic retainer that is screwed on the horn ring but I do not see anything that would insulate the button from hitting the side of the steering wheel to keep it from making contact, and sounding the horn. But I am not very experienced with this type of horn set up.
Any pics or other info to help?
Thanks
Gene
1965 F100
C2oZ13A821A .. Horn Brush & Insulator Kit
The insulator is a plastic sleeve. It fits into the hole in the wheel, the brush fits inside it.
I have a plastic retainer that is screwed on the horn ring but I do not see anything that would insulate the button from hitting the side of the steering wheel to keep it from making contact, and sounding the horn. Thanks Gene
Take that plastic retainer and metal plate off, underneath it is a cushion (pad).
Over time it collapses. You may need this cushion along with the brush and insulator I listed in my last post.
