loud squeak? idk
Old Apr 25, 2008 | 06:26 AM
That_Just_Happened's Avatar
That_Just_Happened
loud squeak? idk
This is one of those tempermental squeeks...when the wheel is turned to the right...just in the perfect spot the truck makes this loud squeaking noise...i don't know where it is coming from...there is no vibrations it just gets embarasing when i go around a bend in the road. It sounds like it is coming from the front drivers side by the tire, but i don't see anything wrong. I recently had the ball joints replaced, brakes replaced. thank a lot
Old Apr 25, 2008 | 06:57 AM
ron's power stroke's Avatar
ron's power stroke
just happend to me last week..when i turned right i would hear a squeal..pitch was with speed...turned out the dust shield around the front driver side rotor had got bent a little and the rotor and shield would rub together when turning right......
Old Apr 25, 2008 | 07:00 AM
dieselboy3278's Avatar
dieselboy3278
my 03 did the same thing and it was the driver side ball joints
how i found the spot was take some jb blaster penatrating oil
have some one turn the wheel back and fourth while you spray and listen
if not the ball joints try it else where process of elimanation
hope this helps
Jenksie13
Feb 24, 2015 10:47 AM
KJR05
Mar 1, 2014 10:36 AM
ccllud
Feb 13, 2014 09:07 PM
brc777
1983 - 2012 Ranger & B-Series
Apr 3, 2012 04:06 AM
sludges squaw
1997 - 2003 F150
Oct 4, 2006 08:21 PM
