air blowing back thru air filter
The sound you hear is what folks call a "turbo fart". It is said to happen on all engines, just more pronounced when you have an aftermarket air filter. I have never heard it on my truck.
Other than what you have described how does the truck run and you say it is only when you let off the gas and no other time.
You didn't remove the MAF to install your K&N did you?
From the 05 shop manual:
<TABLE cellSpacing=0 cellPadding=3 width="70%" border=1><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1 </TD><TD>9C632 </TD><TD>Turbo intake pipe-to-air cleaner clamp</TD></TR><TR vAlign=top><TD>2 </TD><TD>9B659 </TD><TD>Turbo intake pipe-to-air cleaner pipe</TD></TR><TR vAlign=top><TD>3 </TD><TD>9C632 </TD><TD>Air cleaner pipe-to-air cleaner clamp</TD></TR><TR vAlign=top><TD>4 </TD><TD>— </TD><TD>Mass air flow (MAF) electrical connector (part of 12A581)</TD></TR><TR vAlign=top><TD>5 </TD><TD>W709327 </TD><TD>MAF sensor bolts (2 required)</TD></TR><TR vAlign=top><TD>6 </TD><TD>12B579 </TD><TD>MAF sensor</TD></TR><TR vAlign=top><TD>7 </TD><TD>9643 </TD><TD>Air cleaner outlet housing</TD></TR><TR vAlign=top><TD>8 </TD><TD>9601 </TD><TD>Air cleaner element</TD></TR><TR vAlign=top><TD>9 </TD><TD>9F823 </TD><TD>Air cleaner inlet housing</TD></TR><TR vAlign=top><TD>10 </TD><TD>W527376 </TD><TD>Auxiliary air intake hose clamp</TD></TR><TR vAlign=top><TD>11 </TD><TD>9C676 </TD><TD>Auxiliary air intake hose</TD></TR></TBODY></TABLE>
