air blowing back thru air filter
Old 04-23-2008, 08:48 PM
another ford's Avatar
another ford
another ford is offline
have a 05 6.0 its blowing air back through the air filter when turbo slows down and also puffs black smoke at higher speeds when turbo blows back through any ideas what this is and also getting about 7 mpgs
Old 04-23-2008, 09:50 PM
bismic's Avatar
bismic
bismic is online now
Received 2,598 Likes on 1,808 Posts
more info please -
miles on truck?
any mods?
CEL?
any DTC's thrown?
what are your filter change intervals?
what filters do you use?
Old 04-23-2008, 09:58 PM
another ford
66000, k&n just bought put 1000 miles no codes just did k&n from stock now noise is louder and moer noticable and alsothe turbo boost gauge fluctuates when noise is present sounds like a big continuous burp whin you let off accell pedal
Old 04-23-2008, 10:00 PM
another ford
no mods all stock
Old 04-23-2008, 10:05 PM
bismic's Avatar
bismic
Most folks here will say a K&N filter offers no benefits unless you are heavily modded and it jeopardizes your turbo due to poorer filtration than stock. Also, oiled filter elements have been known to negatively affect your Mass Air Flow sensor.
The sound you hear is what folks call a "turbo fart". It is said to happen on all engines, just more pronounced when you have an aftermarket air filter. I have never heard it on my truck.
Old 04-23-2008, 11:04 PM
3000 FPS's Avatar
3000 FPS
3000 FPS is offline
Other than what you have described how does the truck run and you say it is only when you let off the gas and no other time.
Old 04-24-2008, 06:11 AM
another ford
doesnt have map sensor never did it runs crappy when going about 70mph,puffing black smoke everytime it surges , it surges alot and will run out of power! its like the turbo builds up pressure and it is letting it out at all speeds.
Old 04-24-2008, 06:21 AM
bismic's Avatar
bismic
who said anything about a MAP sensor?
Old 04-24-2008, 06:33 AM
bismic's Avatar
bismic
You didn't remove the MAF to install your K&N did you?
From the 05 shop manual:
<TABLE cellSpacing=0 cellPadding=3 width="70%" border=1><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1 </TD><TD>9C632 </TD><TD>Turbo intake pipe-to-air cleaner clamp</TD></TR><TR vAlign=top><TD>2 </TD><TD>9B659 </TD><TD>Turbo intake pipe-to-air cleaner pipe</TD></TR><TR vAlign=top><TD>3 </TD><TD>9C632 </TD><TD>Air cleaner pipe-to-air cleaner clamp</TD></TR><TR vAlign=top><TD>4 </TD><TD>— </TD><TD>Mass air flow (MAF) electrical connector (part of 12A581)</TD></TR><TR vAlign=top><TD>5 </TD><TD>W709327 </TD><TD>MAF sensor bolts (2 required)</TD></TR><TR vAlign=top><TD>6 </TD><TD>12B579 </TD><TD>MAF sensor</TD></TR><TR vAlign=top><TD>7 </TD><TD>9643 </TD><TD>Air cleaner outlet housing</TD></TR><TR vAlign=top><TD>8 </TD><TD>9601 </TD><TD>Air cleaner element</TD></TR><TR vAlign=top><TD>9 </TD><TD>9F823 </TD><TD>Air cleaner inlet housing</TD></TR><TR vAlign=top><TD>10 </TD><TD>W527376 </TD><TD>Auxiliary air intake hose clamp</TD></TR><TR vAlign=top><TD>11 </TD><TD>9C676 </TD><TD>Auxiliary air intake hose</TD></TR></TBODY></TABLE>
Old 04-24-2008, 06:40 AM
another ford
no never had place for one have plug though
Old 04-24-2008, 08:43 AM
69cj's Avatar
69cj
69cj is offline
Me thinks you need to go back to a stock filter and replace any other parts that have been removed and start from there.
Old 04-25-2008, 11:32 PM
another ford
spelling bad maf sensor
Old 05-13-2008, 08:50 PM
another ford
was a bad turbo
Old 05-13-2008, 11:27 PM
3000 FPS's Avatar
3000 FPS
3000 FPS is offline
was a bad turbo
Thanks for letting us know. The turbo sure does seem to be a pretty common problem with the 6.0L. I keep a spare in the garage.
Old 05-13-2012, 08:29 PM
timberon94f350's Avatar
timberon94f350
timberon94f350 is offline
Thread resurrection
Our 03 is doing pretty much the same thing & it's bone stock. Had a family member say it's the o2 sensor more than likely. What happens when one (o2 sensor) goes out? Thanks!
Quick Reply: air blowing back thru air filter
