2000 ranger 4.0 code p1451
Old Jan 22, 2009 | 12:06 PM
paulmdahle's Avatar
paulmdahle
Please help. Code p1451. no voltage at cv solinoid. Checked for damaged wires and connections, OK. purge valve OK. What else might I check???
Old Jan 22, 2009 | 06:47 PM
pawpaw's Avatar
pawpaw
Check the purge valve solenoids electrical resistance, to see if it's open circuit.
If it's not open circuit, connect a voltmeter to the solenoids electrical connector & see if it's getting a signal/voltage for the solenoid to open & purge the vapor recovery canister after the engine is started.
Let us know what you find.
Old Jan 23, 2009 | 01:20 PM
paulmdahle's Avatar
paulmdahle
Thanks for the info. I did discover the problem after much headscratching and wire loom connection checking, corroded fuse connection. First thing I did was check the fuse with a test light, good, however the output side of the fuse was crusted with gunk.
Old Jan 23, 2009 | 02:57 PM
pawpaw's Avatar
pawpaw
Ok, good trouble shooting & feedback & to hear you've found & fixed your problem.
Yup that corrosion at the power fuse can cause a voltage drop under load, that might affect the purge solenoids operation.
Thanks for closing out your thread.
Jbartlett09
May 29, 2017 08:45 AM
lgeiger13
Modular V8 (4.6L, 5.4L)
31
Jul 22, 2016 10:53 PM
iateatoad
13
Dec 8, 2012 10:35 PM
BURNSTOUGHFORD
1997 - 2003 F150
Jun 25, 2008 06:48 AM
Stangfire
1997 - 2003 F150
Apr 29, 2008 08:51 AM
