engine overheat after manifold install.
Old Jan 23, 2002 | 10:01 PM
55forder's Avatar
55forder
Hello friends.
I just installed an Edelbrock performer intake manifold, and a Holley 600 carb on my 1977 302. I took out the old thermostat and just figured I'd run it straight through(friend said it would make me run cooler) I let her idle for about 20 minutes, and got up to 180 degrees, plus I smelled that smell of an engine overheating-you know the one. With the 2bbl, and the old intake, I never got that hot but now I'm heating rapidly. Any suggestions?
Thank you.
Old Jan 24, 2002 | 07:12 AM
slikness's Avatar
slikness
You've probably got some air in your system causing poor coolant circulation. Not running a thermostat will make the system more susceptable to air in the system. Try running your truck with the radiator cap off to allow the air to escape as it circulates and keep an eye on the fluid level. Add fluid as necessary, but be careful, the engine does not like getting an ice cold splash of coolant when it's hot!!! Add just a little and slowly. You can also squeeze the upper radiator hose to help work the air out of your system. I would recommend using a thermostat...that will help the engine get to operating temperature quicker and help maintain a constant temperature while running.
Old Jan 24, 2002 | 10:53 AM
airharley's Avatar
airharley
Also to get trapped air out of your system with a thermostat, drill a 1/8" hole in it. Just make sure you don't drill the sealing surface.
Old Jan 24, 2002 | 02:59 PM
rc351w's Avatar
rc351w
>I took out the old
>Thank you.
55forder,
Your friend gave you some bad advice. I once asked a friend of mine about running without a thermostat (he races stock cars with his father). He told me NOT to and explained why. "Without the thermostat, or a restrictor plate, the water circulates too fast and doesn't remain in the rad long enough to cool to the proper temperature." This is even more a problem when sitting idling.
If your wanting to run cooler, get a 180 or even a 165 thermostat.
RCC
Old Jan 24, 2002 | 05:14 PM
galaxiefiveohoh's Avatar
galaxiefiveohoh
One more thing. It is very possible and very easy to have installed the head gasket incorrectly which will block your cooling passage. More guys have wet the bed trying to figure this one out.
Old Jan 24, 2002 | 07:14 PM
55forder's Avatar
55forder
I got a 180 degree thermostat, am going to install it tomorrow. Thanks for the help fellas. Oh! it might help to add some coolant as the previous owner obviously has it full with H20.Whats the best way to flush my radiator? (lots of rust).
Old Jan 24, 2002 | 08:08 PM
airharley's Avatar
airharley
The best way I can think of is using a prestone flush kit with the flush/cleaner. You can run H2O in your engine as long as you add a rust inhibitor. Also look for a product called wetter water. It helps to disperse heat better then plain water or anti-freeze/water. But remember it is a additive.
Old Jan 25, 2002 | 01:05 AM
Franklin2's Avatar
Franklin2
ForKyleigh
Modular V10 (6.8l)
Oct 25, 2019 08:53 PM
JRB65
Feb 16, 2013 12:05 PM
carlmaass
Jul 5, 2011 06:51 AM
cartier46
Modular V8 (4.6L, 5.4L)
Aug 30, 2003 11:49 PM
SkyBlue69
Dec 16, 2002 12:24 AM
