alternator help
Old Apr 22, 2008 | 08:36 AM
bambam634's Avatar
bambam634
alternator help
does any body know how to replace an alternator on a 1995 explorer 3.8 i am having problems with the voltage regulator i was told
Old Apr 22, 2008 | 06:30 PM
aquanaut20's Avatar
aquanaut20
yes we do, but what seems to be the problem?
Old Apr 22, 2008 | 09:20 PM
steve(ill)'s Avatar
steve(ill)
there is an idler pulley on the end of an aluminum arm that is the belt tensioner. there is a 3/8 square hole in the arm by the pulley. you use a breaker bar to compress the arm spring, then jump the belt off the pulley.--- i think you have the alternator that bolts to the top of the mount with three bolts from the top. just take out the three bolts, slide to the side, and get the wire harness off the back.-- install the new alternator in rev.
Old Apr 23, 2008 | 04:36 AM
marragtop's Avatar
marragtop
What makes you think the alternator is bad? Did you load test it, or are you hearing a squeal and assuming its the alternator. If it's a squeal, it could just be the tensioner. Also, if you do replace the alternator, remember to disconnect the battery first.
Old Apr 23, 2008 | 05:44 AM
Bear River's Avatar
Bear River
Former ******
Also, the Explorer didn't come with a 3.8L, the options were 4.0L V6 or 5.0L V8 for your year.
Old Apr 24, 2008 | 08:51 PM
Gervis's Avatar
Gervis
Hope the following steps will help you out: 1. Disconnect battery ground cable. 2. Disconnect wiring at voltage regulator. 3. Remove attaching nut and wiring terminal from alternator output terminal. 4. Disengage drive belt from alternator. 5. Remove alternator mounting bolts, then the alternator. 6. Reverse procedure to install. 7. Torque bolts to 30-40 ft lb.
And I must agree that the Ford Explorer do not have a 3.8L option.
Old Apr 25, 2008 | 07:30 AM
bambam634's Avatar
bambam634
sorry it was a 1996
1979BEAST
21
Jan 26, 2012 04:34 PM
ktz78
Dec 20, 2010 11:10 PM
robjef
Electrical Systems/Wiring
Oct 24, 2010 04:06 PM
yukgoon
Apr 5, 2009 03:42 PM
lasthighboy
Nov 30, 2008 05:07 PM
