Need help with a 95 Explorer
Old Apr 24, 2008 | 09:16 PM
rayraystringer's Avatar
rayraystringer
Unhappy Need help with a 95 Explorer
We are in need of some major help. We have a 95 ford explorer 4.0 4x4. Lately we will be driving down the road and it just dies like it is out of gas but it isn't and after about2 or 3 mins. it starts right up. So we took it to Auto Zone to run the codes and see what is going on. Well they said it was code 4095 but they didn't know what that code was for..Could someone Please help us! Thanks
Old Apr 24, 2008 | 11:30 PM
mrshorty's Avatar
mrshorty
The vast majority of '95's are EEC-IV/OBD-1. Did Autozone pull the codes using the connector under the steering wheel or under the hood?
Can you put a fuel pressure gauge on it when it stalls to see if it is getting fuel? Can you hear the fuel pump run when it stalls and won't restart?
Old Apr 24, 2008 | 11:34 PM
rayraystringer
Unhappy
They used the one under the wheel. They never hooked it up under the hood. If you can tell I don't know much about this. I don't own a pressure gauge and also I do hear the pump running when it won't start. Thanks so much for the response. We just don't know where to go from here and don't have the money right now to put it in the shop and pay a big bill. Thanks
Old Apr 25, 2008 | 09:12 AM
marragtop's Avatar
marragtop
AZ didn't pull the codes correctly. The 95's have a dummy OBDII port under the steering wheel. The codes need to be pulled from the OBI/EECIV connection under the hood. Get them to pull the codes again. The next time it won't start, I suggest checking for spark since it sounds like the fuel pump is running. It could also be a bad FP regulator or maybe a clogged fuel filter. You need to determine if it is a fuel delivery or spark issue.
Amber Hankins
Aug 17, 2016 09:53 AM
luxury 4x4
May 23, 2016 01:35 PM
bean440
Feb 4, 2006 04:19 PM
penn
Apr 25, 2005 01:12 PM
jamesmonty
Jul 18, 2003 11:11 PM
