Tekonsha P3 brake controller.
Old 04-18-2008, 03:37 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Question Tekonsha P3 brake controller.
I just received my brake controller, and I want to ask if I could position it in an almost vertical position? I want to reduce the distance between the dash en the controller and get more space in the cab.
Thanks in advance.
Old 04-18-2008, 03:39 PM
jimwilsonmasonry's Avatar
jimwilsonmasonry
jimwilsonmasonry is offline
i have the same brake controller i have it mounted under the cubby hole its out of the way of everything there
Old 04-18-2008, 03:43 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
but is in horizontal or almost vertical position?, I also put it under the cubby hole. thanks
Old 04-18-2008, 03:45 PM
jimwilsonmasonry
horizontal well its on a sliding bracket it will go horizontal or vertical
Old 04-18-2008, 04:42 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
Jose I can't remember what it said about mounting position but I do remember info in the instruction book about the mounting positions.
Old 04-18-2008, 05:48 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Unhappy
Thanks friends. TJ in the instructions they say that should be in an horizontal plane viewing the fase of the controller and in parallel with the midline of the truck, but nothing about horizontal or vertical viewing fron back to front. I have seen here some pics and seems that they are a little inclined but Im not sure, thats why as asked. and they say that the controller itself adjusts if you are uphill or downhill, maybe it doesnt mater if its horizontal or inclined.
Old 04-19-2008, 10:51 AM
MagKarl's Avatar
MagKarl
MagKarl is offline
Those Tekonsha units sure are nice, well worth the extra cash. You'll like it. I put one in the wife's Excursion and it sure is smooth compared to the regular old fashioned controller in my pickup. I need to update the harness in the pickup so I can just borrow her controller.
Old 04-19-2008, 02:50 PM
Cuda_jim's Avatar
Cuda_jim
Cuda_jim is offline
Jose, That's the beauty of the digital brake controllers like yours. No need to worry about setting the horizontal for an incline. It senses where level is unlike the type I have....always needs adjustment, especially when I bump it and didn't notice
I'm getting tired of constantly fooling around with it...I'm getting one.
Old 04-21-2008, 01:49 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Thanks amigos for your input, I also asked this in the Towing forums and the answer was, that it could be from 0-70 degrees, like the prodigy, but no one has read that in some paper or on line instructions (for the P3), I watched the DVD and also there, they dont mention that, they say: read it in the instructions paper. In the DVD they install the control in an inclined position, and I just did it in the similar position, also some mentioned that the screen display will show you an ad if it is in wrong position , I didn see anything, at least as I installed.
thanks againg
Angry_Clown
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
09-12-2016 09:14 AM
Diesel_Brad
25
09-27-2015 06:33 AM
mini_blaine
26
12-07-2011 12:43 PM
Piffery1
02-25-2010 07:16 AM
zero9nine
11-08-2007 12:43 PM
Quick Reply: Tekonsha P3 brake controller.
