Door auto lock question
Old Apr 17, 2008 | 03:52 PM
HowieE's Avatar
HowieE
I have a 2004 Ex and the doors auto lock every time the truck goes down the road. That feature is not necessarily a problem but when I stop and turn the truck off only the front doors are unlocked. The 2 rear doors and the back door remain locked and it is a pure pain in the ***.
The Ford manual doesn't even mention this function. Can it be over ridden so all doors are open when the ignition is turned off?
Maybe someday I will learn to unlock the doors before I am halfway to the rear of the truck. But it would be much nicer if they just unlocked as automatically as the lock.
Old Apr 18, 2008 | 01:38 PM
daddgonemadd's Avatar
daddgonemadd
Mine had a procedure in the manual using the keyless entry pad. Look there if you have that option.
Old Apr 18, 2008 | 02:01 PM
HowieE's Avatar
HowieE
Yes the keyless pad will open all doors from the outside by hitting the last number of the code a second time. My question is when exiting the truck only the 2 front doors are unlocked when the ignition is turned off. Those in the back seats and the rear trunk door remain locked until I release them with the switch on the arm rest.
Not sure I want my passengers to be prisoners.
Old Apr 18, 2008 | 02:35 PM
daddgonemadd
I don't have the manual in front of me, so I will have to post later if you can't find it. There is a specific procedure of entering the factory fixed code in the keypad and then holding two other buttons I think until the locks cycled, and then the locks won't lock on their own when put in drive.
Old Apr 18, 2008 | 03:20 PM
HowieE's Avatar
HowieE
Thanks
I found what you were referring to in the manual and got the lock changed.
BigBlueX
Apr 6, 2016 10:33 PM
cecilt
Dec 7, 2009 04:18 PM
skipppy75
Jul 7, 2008 11:56 PM
simoniztexas
Jan 27, 2008 04:18 PM
dapgar
Jan 23, 2007 11:23 AM
