Sponsored by: Kumho
steering column problems
Old Apr 15, 2008 | 05:53 PM
Okcdiscgolfer's Avatar
Okcdiscgolfer
1989 Bronco
5.0 302 V8
Tilt steering
I had a small problem that has become a MAJOR problem.
My ignition (key) stopped working forcing me to start the truck at the solenoid. This happened about 3 weeks ago. That is minor problem to me.
Today the problem has gotten worse. ALOT worse.
Now I can not shift gears at all. The tranny shifts fine under the truck. It appears that it is bound up in the column. I could find no reference to the workings of the column in my Hayes manual. So I ask........ is the column a hard thing to work on? Or should I send to a pro?
Anyone have any ideas as to what the problem may be? Or how I should resolve it.
I thank you in advance for your expert help.
Dave
Old Apr 16, 2008 | 12:02 PM
Lazy K's Avatar
Lazy K
You have a problem common to these trucks. Your ign. key barrel turns a small gear wheel which meshes with a toothed rack. This rack is connected to piece called the ign. switch actuator. This in turn is connected to a rod which runs the steering column to the electrical ign./start switch. Unfortunately the ign. switch actuator also locks the trans. shift lever in Park. Quite often when they break the actuator not only fails to operate the ign./start switch but will not allow the shift lever to come out of Park. The ign. switch actuator is only about $6 but takes a couple of hours to fit. You will have to pull the steering wheel then the turn signal switch plate (3 screws) and then slide the steering column cover off. You will then see the actuator. It is a real PITA to fit, it`s up to you if you want to leave it to a shop.
Old Apr 18, 2008 | 03:23 PM
Okcdiscgolfer
Problem fixed
lazy k......
Thank you.
I was able to fix it in about 2 1/2 hours.
I also posted in the Big Bronco forum and was given a link to an article with pics that was very helpful.
It was not too bad of a fix since I have had to replace the turn signal switch in the past I was a bit familiar with the column.
Good thing is..... when I was done I had no extra parts.
Thanks again.
Dave
JDBeck23
Sep 25, 2012 03:46 PM
crossf-150
Feb 6, 2008 06:03 PM
ford-nut
Feb 25, 2005 07:35 PM
dj9124
Dec 1, 2003 08:05 PM
mirrormaker
Aug 21, 2003 12:06 PM
