Question about the overhead computer
Old Apr 15, 2008 | 05:19 PM
sltrrco's Avatar
sltrrco
I have a quick question - I have a '04 X - It has the 44 gal unleaded tank in it, My question is everytime I fill up it say 398 miles tell emtpy. And I am only putting in 38-39 gals each time. Is any way to fix this?
Old Apr 15, 2008 | 05:20 PM
katiesdad7's Avatar
katiesdad7
Did you try resetting it. YOu hold both buttons down to reset it.
Old Apr 15, 2008 | 05:29 PM
sltrrco's Avatar
sltrrco
I reset it at every fill-up.
Old Apr 15, 2008 | 05:37 PM
Monsta's Avatar
Monsta
Sit. Stay.
What is it exactly that you want to fix?
Old Apr 15, 2008 | 06:39 PM
VaSheriff's Avatar
VaSheriff
I don't see a problem. If I could 398 miles out of 38, 39 or 44 gallons, I would be one happy camper.
44 gallons takes me 350 miles at best. I am only getting 8.2 or 8.3 mpg consistently.
Old Apr 15, 2008 | 06:42 PM
Yesprofit's Avatar
Yesprofit
I believe it depends upon your average gas mileage. I read that it takes the average over a number of miles and computes it that way.
Old Apr 15, 2008 | 06:55 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Thanks weird mine says 745 miles to empty when I fill up
Old Apr 15, 2008 | 07:19 PM
MarkMoore's Avatar
MarkMoore
It's my understanding that the computer calculates mileages over the last 500. I believe that if you disconnect the neg battery terminal and then turn on the headlights (this disipates any residual power) - let it sit for about 15 minutes, then turn off the headlights and reconnect the batt terminal. This should reset the PCM back to scratch. For the next few miles, you'll notice that the tranny will shift a little firmer while the PCM's 'Adaptive Technology' re-learns your driving style. During this time, drive as normal as possible.
Few other points - I do this procedure everytime I change the air cleaner, clean the MAF or change the fuel filter.
Also - you may want to write down all of your radio station pre-sets... they will be lost.
Old Apr 15, 2008 | 07:44 PM
ptolalibertad's Avatar
ptolalibertad
after you reset the computer..it will start where you are...i think......the miles to empty will change over time also..if you go 15 miles per gallon..after a time the computer will reflect it..maybe..
Old Apr 16, 2008 | 10:34 AM
VaSheriff's Avatar
VaSheriff
Yeah. But that's because you have the magical diesel engine which is 50 times better than a V-10
and has enough torque to pull a fully loaded aircraft carrier uphill in 24" of snow!
Old Apr 16, 2008 | 06:16 PM
chazman's Avatar
chazman
Reset the miles per gallon first after a fill up. Mine usually reads 644. //04 6.0 psd 4x4.
Old Apr 17, 2008 | 12:00 PM
RACERX7775's Avatar
RACERX7775
chaz, did you happen to see post #2 and #3? and he has the gas engine... not diesel...
Old Apr 17, 2008 | 12:27 PM
PROSTOCK's Avatar
PROSTOCK
I just spent $138 on a fillup today and it indicates 580miles...which is about right for driving we are doing.
Old Apr 17, 2008 | 11:16 PM
ptolalibertad
when my wife drives city..at fill up..450 miles or so indicated..when we travel open highway it goes up to 680...the computer is fairly accurate
cbr600f31997
Apr 14, 2014 04:41 PM
Dutch123
2009 - 2014 F150
13
Oct 14, 2011 06:55 PM
Ted928
2004 - 2008 F150
19
Apr 5, 2006 01:39 PM
stan v
Dec 10, 2005 07:41 PM
kawika
Dec 28, 2004 09:55 PM
