electronic component identification question
Old Apr 15, 2008 | 12:49 PM
mattsautobody442's Avatar
mattsautobody442
Lightbulb electronic component identification question
I am putting a 7.3l idi diesel with an e4od from a 92 f250 2wd xlt into my 1977 f250. i was looking for the module that directly controls the trans since the engine is apparently not computer controlled. i cut out the steel black box from behind the glove box, the plastic module thats behind the dash under the steering column, 2 plugs can be reached easily. am i missing something? i dont want to spend $500 on a controller. any help or schematics, let me know. thanks
Old Apr 15, 2008 | 01:02 PM
Conanski's Avatar
Conanski
In the gas trucks the computer is housed in the driver's side kick panel, is there anything in this location? BTW... this computer runs both the engine and tranny in the gas trucks, I have no idea if the same thing is used on the diesel trucks.
Old Apr 16, 2008 | 12:08 AM
mattsautobody442
no, there's just a cavity, but i am curious as to what the black metal box is behind the glovebox, there no airbags....
Old Apr 16, 2008 | 01:58 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Two possibles:
Emission Throttle Position Control Actuator Assy / Marked: D5HF-9F441-AA OR D7HF-9F441-AA.
Intermittant Wiper Governor / If marked, will include Ford basic # 17C476.
Intermittant wipers were an optional accessory back then, so not all trucks will have it.
No airbags or processors (computers) were used in the 1970's.
Old Apr 16, 2008 | 05:01 AM
EPNCSU2006's Avatar
EPNCSU2006
The black box sounds like the RABS controller. I would check in the normal engine computer location behind the driver side kick panel (accessed from under the hood - you'll have to loosen the fender liner to get it out) for the transmission controller.
Old Apr 16, 2008 | 10:18 AM
mattsautobody442
what does RABS stand for?? i better hurry back to the junk yard before they crush the truck
Old Apr 16, 2008 | 10:36 AM
Conanski's Avatar
Conanski
RABS = Rear Antilock Brake System
Old Apr 16, 2008 | 10:38 AM
Conanski's Avatar
Conanski
Where does the electrical harnes that comes off the tranny go?
Old Apr 17, 2008 | 12:12 AM
mattsautobody442
under the the distribution box to the firewall.. so now im realizing that the controller is in the same place as the ecm.... so now the new question is where can i get a diagram so i can wire the trans and tcm together..... any insight?
Tkrobinson
Dec 7, 2018 08:22 PM
Racerguy
1997 - 2003 F150
18
Nov 2, 2016 06:26 AM
Dustin McComas
Sep 30, 2015 09:24 AM
f15olandscape
Apr 6, 2015 10:32 PM
892504x4
Dec 3, 2014 07:40 PM
