Modular V10 (6.8l)
Exhaust Muffler
Old Apr 15, 2008 | 11:48 AM
Trucker51's Avatar
Trucker51
Exhaust Muffler
I have a 2005 Excursion v10.
I want to put in a Cut out and run one side to the stock muffler, for when i need it "quieter" and the cut out end to a Flowmaster 40. Is there any way to get the exhaust to switch from the stocker to the flowmaster? The electric cut outs are way to much.
If i get the Mr. Gasket cable cutout, its only a 2", will this hurt it if i run this?
thanks
Old Apr 15, 2008 | 03:11 PM
dkf's Avatar
dkf
You NEED a 3" cutout, 2" or 2.5" will be a major restriction point and kill power. Honestly I would throw on an FM50 SUV muffler with the stock tubing and exit location sound will be in between the FM40 and stock muffler.
Old Apr 15, 2008 | 06:26 PM
meanv10's Avatar
meanv10
Doing all that work will add a lot of weight, and probably wont be to cheap.
I agree with DFK either a 50 or 70 and you will be fine.
Beside what are you planning on, picking up your date with the loud exhaust and then quietly rolling back to her house to drop her off at the wee hours of the morning with the factory exhaust?
Old Apr 15, 2008 | 09:23 PM
Trucker51's Avatar
Trucker51
i guess what i really want is a muffler that sounds nice and deep at idle, but when you get on it is loud, and with no drone in the cab. Will the FM 40 or FM 50 do this if running through all stock piping?
Old Apr 16, 2008 | 07:38 AM
djhuff's Avatar
djhuff
I've got a 50HD on mine, it drones a little when I rolling down the road at 55 in OD (right around 1500 rpm). Other than that, it's not much louder than stock with all the windows up.
Old Apr 16, 2008 | 07:39 AM
djhuff's Avatar
djhuff
oops, I did the e-bay y pipe mod as well.
Old Apr 16, 2008 | 01:48 PM
dkf's Avatar
dkf
An FM40 will give you drone and smaller case FM50s might as well. The 50 HD muffler is louder than the FM50 SUV and doesn't have the larger anti-drone chambers the 50 SUV has.
Heres a link to a sound clip of an FM50 SUV muffler on a bone stock V10 excursion with a single 3" system.
YouTube - 2002 Ford Excursion 6.8L V10 Flowmaster
Old Apr 17, 2008 | 01:45 AM
skipperw's Avatar
skipperw
Is this the cutout you are looking for? It is right before muffler.
Old Apr 17, 2008 | 10:27 AM
Trucker51's Avatar
Trucker51
yes that is exactly what im looking for. My problem is the o2 sensor is right there. could i take it out and drill a new hole for it in the cutout, and put it back in?
Old Apr 17, 2008 | 10:37 AM
meanv10's Avatar
meanv10
You can do that, I would put it like 6" back from the cut out, that way when you run it open, it can compensate for the difference in back pressure at Ideal
Old Apr 17, 2008 | 10:56 AM
Trucker51's Avatar
Trucker51
on my Ex, there is only about 15 inches between the cat and muffler. and the cutout is 12 inches long. its gonna be a tight fit.
mxer0022
Sep 21, 2016 06:07 AM
nuts4hotwheels
Exhaust Systems
Mar 18, 2005 10:17 PM
Rukmns
Exhaust Systems
Feb 5, 2005 01:51 AM
xallxforxchristx
Exhaust Systems
30
Jun 17, 2004 11:57 PM
Wakeboarder141
1978 - 1996 Big Bronco
Oct 1, 2003 05:37 AM
