it started yesterday morning, i was having trouble getting it in to gear so i thought it might be low on fluid. it was a little low so i topped it off and it ws a little better, but when i got in it lastnight i had a really hard time getting it in gear wheni was stopped, but i could pump the clutch and get in to gear. i made it home but now it wont go in gear at all! the fluid hasnt gotten any lower. i tryed to bleed it this morning but i cant get anything to come out.
can someone tell me a little more about how to bleed the clutch? or what they think the problame might be??
you said you cant get any fluid to come out when you crack the bleeder and pump the pedal this could mean your master cylinder is bad you slave could be fine if this is what you said i would try changing the master which is easy and cheap
i couldnt agree more about how RETARTED the internal slave is im very happy that 3 of my 4 vehicles including the 95 powerstroke ZF5 i just bought have external slaves because ive changed enough of the internal slaves to make my head spin and im done owning vehicles that have them its crazy the diesel zf5 have external slaves but the gas zf5 have internal what is ford thinking ive debated replacing my m5r2 with a t19 in my f150 just to solve this problem
