56 Chassis matching
Old Apr 13, 2008 | 09:13 AM
3golfjack's Avatar
3golfjack
56 Chassis matching
I, ve been looking for a 56 chassis. There is a 56 listed on ebay in Jackson,Ms but there a question about this chassis whether are not is it a 56. My question is if this is a 50 thru 55 chassis will it match up with a 56 cab.
Old Apr 13, 2008 | 09:20 AM
3golfjack's Avatar
3golfjack
After seaching thru earler postings it appears the 53 thru 56 match pretty close.
Old Apr 13, 2008 | 09:35 AM
Fomoko1's Avatar
Fomoko1
To the best of my knowledge the frames are interchangeable.
Old Apr 13, 2008 | 10:04 AM
jaye's Avatar
jaye
3golfjack,
If you are referring to the "56" frame in Hammond LA, that is not a "56" frame. Where are located, as far as I know the 53-56 are interhangeable however, the rear springs on the 1953-54 were 48” eye to eye and 1955-56 are 52. both rear springs are 2” wide
Old Apr 13, 2008 | 02:04 PM
WALFORD'S 56's Avatar
WALFORD'S 56
The Hammond,La frame does not look like my 56F100 frame. I wonder what it is also?
Old Apr 13, 2008 | 05:57 PM
3golfjack's Avatar
3golfjack
I elected to pass on the Hammond,La frame. Just wasn, t sure of it.
Old Apr 13, 2008 | 06:13 PM
jaye's Avatar
jaye
I changed my frame a little over a month ago I have a "55" the frame I used was a "53 or 54" because they have the hole in the rear for the bumper I went to the local salvage yard and picked one and the guys there stripped it down to nothing I wire brushed it and put POR-15 on it I have the TCI rear spring kit and the drop front axle I haven't driven it yet I still a few more wires to and the bumper to install then get a front end alignment and it should be good then, I'll post some pic of thr before & after when I'm completed
Old Apr 17, 2008 | 07:24 AM
Aussie 53's Avatar
Aussie 53
I do believe the frames from 53-56 are interchangable. I guy here in Aussie was selling a 56 body on a 53 frame. The reason why I said that because the vin number quoted was F103L10447.
Old Apr 17, 2008 | 05:19 PM
SCD's Avatar
SCD
I have a 53 with a 56 cab. I will be swapping it all over to a 54 frame later this year. As mentioned on a previous response, the springs are shorted on the 53 and 54 frames.
Scott
