Tachometer Question.......
Old Apr 12, 2008 | 05:19 PM
FitchBanjos's Avatar
FitchBanjos
I just put a new Auto Meter tach in my trucka dn for some reason, it only registers the correct RPM when I put it on the 6 cyl. setting. I have a V-8 . Any idea why?
Old Apr 12, 2008 | 06:09 PM
KILLER'S_60&66's Avatar
KILLER'S_60&66
Fitch~
I have an autometer tach as well and I have it set on the V8 setting and I have always thought that it worked fine. How did you know any different? I have a 360CI under the hood and it seems to do just fine in my '66. Let me know!
KILLER
P.S. What is the redline on your truck? The highest I have gone is 3800RPMs
Old Apr 12, 2008 | 06:50 PM
FitchBanjos
On the 8cyl. setting, it was showing a much lower RPM than the actual. I used another new tach that is built into my timing light to compare. On the 6cyl. setting, it is excatly the same as my other tach. i have not pushed the truck to the redline. It is old like me so, I baby it.
Old Apr 13, 2008 | 12:06 AM
KILLER'S_60&66
Hey, thanks for the info! Maybe I have been running mine at a higher rpm than I know, but I have set the idle at 500rpm according to my tach and it seems to be pretty low, but not sputtering or anything like that. I guess I run mine a bit hard becuase I am young and my truck is young at heart like myself! I just raced my buddy on his GS650 and beat him in about a half mile strip...I am purely stock though. I LOVE how durable they make the old boys! Thanks again
KILLER
P.S. Don't worry, I baby my old boy most of the time. He gets lots of rest and is never driven cold. I would hate to be accused of truck abuse..haha!
Old Apr 13, 2008 | 06:32 AM
ddavidv's Avatar
ddavidv
Peak HP on our trucks is somewhere around 3800-4000rpm I think (too lazy to look it up). Revving past that point is just making noise and wasting fuel.
Old Apr 13, 2008 | 06:33 AM
jowilker's Avatar
jowilker
Tachs usually run pretty close. IMHO Your speedo, rear ratio, and things like that can throw off what the perceived rpm is.
There are spreadsheet programs that will help get those answers. This is one source * * Automotive Programs by Bowling & Grippo * *
I think my system is pretty close, I run 235-75-15 tires, through 3.00 gears behind a FE powered C6. At 55 mph, my truck tachs 2050 rpms.
Speedo drive gears, and rear end ratios are often not correctly known and give false readings.
When you have been around these ol trucks as long as I have and a fellow comes in here saying his FE powered truck is getting 18 mpgs everyday, you know something is not right. I believe our trucks are getting better mpgs now than ever, with electronic ign. better carbs, etc.
Keep digging Cliff, I'll bet you will figgure it out.
John
Old Apr 13, 2008 | 07:33 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Tire sizes in the 1960's for F100's were: 7:10-15 / 7:60-15 / 8:00-15 / 8:20-15.
Today they're all P Metric Sizes.
The change to P Metrics means the speedometer can be off between 7 and 14 MPH, or more.
To correct the speedometer, one needs to know what the P Metric sized tire on the vehicle converts to inre 1960's sizes.
Once that's known, the speedometer's driven gear can be matched to the P Metric tire size, installed in the trans, replacing the original = the speedo should read correctly.
To arrive at the correct speedo driven gear (end of cable) depends on two factors: rear end ratio, tire size.
dweb4
1978 - 1996 Big Bronco
Aug 24, 2019 05:22 PM
91ford7.3
Jul 9, 2016 02:06 PM
Superwock
Sep 6, 2015 03:20 PM
askintc
Exhaust Systems
Nov 19, 2008 04:32 PM
Epd444
27
Jan 1, 2008 04:55 PM
