Can I Put H-Pipe on
Old Nov 5, 2008 | 04:41 PM
askintc's Avatar
askintc
Can I Put H-Pipe on
I have a 2000 F150 5.4 and i was wondering if it would be possible to put and H-Pipe on with Flowmaster Super 44 or would it be better to put on X-Pipe with same muffler.
Old Nov 6, 2008 | 12:51 AM
Bear River's Avatar
Bear River
Former ******
You can, but do you even have duals? It is often cheaper and easier, and just as effective to run a dual outlet muffler. You can also get cross flow mufflers in most brands which have an internal x pipe.
Old Nov 6, 2008 | 05:43 AM
phil6608's Avatar
phil6608
I like My X pipe.
If I was to redo my system,,,I would go with a muffler with the internal X.
Like was said,,,If you don't have true duals,,,you can use an X or an H.
Old Nov 11, 2008 | 10:15 PM
AspenF150's Avatar
AspenF150
Keep in mind too x pipes are better for mid to top end torque range and flow better than h pipes. X pipes sound great on certain vehicles IMO, but I think they produce a more raspier sound if you will.
On the flip side, h pipes will allow you to keep your low end torque and have a deeper throatier sound.
Old Nov 14, 2008 | 06:50 PM
askintc's Avatar
askintc
but i called a shop about it nd they said tht there wouldnt be ny room for an h-pipe cause of my cats, yea i have split rear but i want louder more agressive sound n other words more manlier
Old Nov 14, 2008 | 11:14 PM
AspenF150's Avatar
AspenF150
they can't just cut the exhaust at the y pipe and install the H pipe true duals from there?
Old Nov 15, 2008 | 12:52 AM
Diesel nut's Avatar
Diesel nut
Yea they should be able to. I just had my exhaust redone and they welded in an h-pipe.[/URL]
Old Nov 15, 2008 | 06:20 AM
phil6608's Avatar
phil6608
If you only have a split rear exhaust,,,that is your problem.
You need a true dual exhaust in-order to put in an H or X pipe.
They would need to cut your Y pipe and run 2 pipes.
In this pic you can see,,,Where the X is,, is where you would put an H or X.
Old Nov 18, 2008 | 03:18 PM
askintc's Avatar
askintc
ea but they said i culdnt put tru duals on becase of my cats
Old Nov 18, 2008 | 03:57 PM
phil6608's Avatar
phil6608
Find a new shop!!!
They have no idea what there talking about!
I have an 03 with true duals. All they have to do is cut the Y pipe after the cats and go from there with 2 pipes.
Old Nov 19, 2008 | 04:32 PM
askintc's Avatar
askintc
so they'll cut it off after the O2 sensor, nd it sounds good
Uni Moe
Jun 5, 2017 11:15 AM
Nick-1973-ford
18
Jul 16, 2016 08:24 AM
Tedster9
37
Jun 11, 2016 10:18 PM
3eggOmelet
13
Mar 18, 2004 04:33 PM
SaleenX
Exhaust Systems
Feb 25, 2004 10:33 PM
